Cork Gasket for FM ZD Cover
this thread has 2 replies and has been viewed 1333 times
Old 03-18-2009, 07:47:51 AM
shoptek shoptek is offline
Default Cork Gasket for FM ZD Cover
A Fairbanks Morse Z model D, did they use a cork gasket on the crankcase cover. If so what thickness, I have not been able to find a ready made gasket for it so I may need to make it. What would you guys use. Could you use regular gasket material or is there not enough give on that. Do you just buy roll material and cut one. Thanks.
Old 03-18-2009, 10:50:10 AM
David M. Lyon's Avatar
Default Re: Cork Gasket for FM ZD Cover
Automotive RTV clear sealer....There ain't nuthin' better!
Old 03-18-2009, 04:31:10 PM
Marty Hitzeman Marty Hitzeman is offline
Check out hi-n-miss enterprises, they have the gaskets you are looking for. I have bought the gaskets from them and they fit great!! Hit-n-miss is listed here on smokstak. Check them out. Hope this helps.
The Following User Says Thank You to Marty Hitzeman For This Post:
What is the best gasket material for a steam chest cover? MarkP Steam Stationary Engines, Traction Engines 16 08-20-2008 12:35:30 PM
Inspection cover gasket material Orrin Steam Stationary Engines, Traction Engines 9 11-08-2007 10:12:11 AM
Gasket Material for CT-2 Stover Crank Cover? DippyNo12 Hit & Miss Gas Engine Discussion 6 08-05-2007 09:55:49 PM
cork float larry harding Antique Engine Archives 3 07-28-2004 08:30:17 PM
Cork Carb Float Kid Dynamo Antique Engine Archives 7 12-18-2000 08:12:29 PM
