Rope Start Round Head FH Briggs
this thread has 4 replies and has been viewed 2003 times
Old 07-26-2009, 09:50:06 AM
Junkologist's Avatar
Default Rope Start Round Head FH Briggs
I have the chance to buy a rope start round head FH Briggs. I'm kind of up in the air with it right now and would like to know what you guys think. The engine was changed from a kick start to a rope start, but it has the proper base and is all correct as far as I can tell. One other downer is that the tag is not original and I don't know if it has the serial number in the right range for the age of the engine. I was told it runs good and has no problems in that area. I can get this engine along with a restored Briggs Q for $800. What do you guys think? Is it too steep?
Mike
SmokStak member #146
Old 07-26-2009, 12:15:01 PM
Sky
Default Re: Rope Start Round Head FH Briggs
As i've always seen it, prices and worth is what it is to you. i think $800 might be a little steep even for the both. Chances are i'd offer 550 or 600 take it or leave it. Not having the proper tag is also sort of a downer as the original history is now gone from it. Then again it also depends on the features of the FH. I dont want to say "no its too steep dont get it" rather then, if it's right to you, then by all means get it.
Old 07-26-2009, 12:19:03 PM
Motormowers's Avatar
I always thought the round head was stopped in 1926 and kick starters didnt come around till 1927. Sounds like its been cobbed up over the years and isnt original.
The Following User Says Thank You to Motormowers For This Post:
Old 07-26-2009, 01:51:37 PM
Bob Krummel Bob Krummel is offline
Is it a straight fin or slant fin? My slant fin FH turned out to be an FE!
Old 07-26-2009, 07:02:17 PM
Bob, it's a slant fin.
Mike
Briggs hard to start when hot. Lead Head Small Air Cooled Gasoline Engines 44 08-02-2017 02:08:58 PM
Briggs 6S Handle start Dennis Wyatt Small Air Cooled Gasoline Engines 19 02-02-2009 08:01:14 PM
Briggs FH slant fin rope start Jim Sherman Small Air Cooled Gasoline Engines 9 04-07-2006 03:31:59 PM
Briggs FH rope start date? Jim Sherman Hit & Miss Gas Engine Discussion 1 01-10-2006 02:41:11 PM
Briggs 5S Recoil Start Rake60 Small Air Cooled Gasoline Engines 19 12-16-2005 12:33:08 PM
