Kohler K341 cycles between fast and slow rpm
this thread has 1 replies and has been viewed 2294 times
Old 08-18-2009, 12:55:17 PM
jomifo jomifo is offline
Default Kohler K341 cycles between fast and slow rpm
Hello all-
I recently acquired a home-made log splitter with a Kohler K341 motor. The motor has been sitting about 5-7 years. I was able to get it started, but it bounces back and forth between high and low rpms with it just about stalling when it reaches the low rpms. This is with the throttle at about halfway. It also just plain out stalls at idle throttle. It does run pretty strong and solid at high throttle.
My first thought is to clean the carb thinking it may be gunked up in there. Any tips on how to clean the carb?
Also, could this issue be governor related?
Thanks.
Old 08-18-2009, 02:58:25 PM
Rodrigue Caron Rodrigue Caron is offline
Default Re: Kohler K341 cycles between fast and slow rpm
Hi. See thread BGE Surging on load Rodrigue
Kohler K341 16HP Head Torque Specs Wheel Horse Guy Small Air Cooled Gasoline Engines 2 05-29-2009 08:44:48 PM
IHC LA running too fast WildIrishman52 Hit & Miss Gas Engine Discussion 1 08-07-2008 08:29:41 PM
K341 Rebuild? Lead Head Small Air Cooled Gasoline Engines 41 03-22-2008 11:01:56 AM
slow running, how slow is good for a herc. engine Mac Leod Antique Engine Archives 2 10-03-2004 11:36:28 AM
How fast is it turning? Bill Blackburn Antique Engine Archives 11 12-29-2002 07:39:44 PM
