Fairbanks serial number question
this thread has 9 replies and has been viewed 1421 times
Old 10-03-2009, 10:27:40 AM
Dave Frost Dave Frost is offline
Default Fairbanks serial number question
I would like to find more information on an engine. It is the throttle type. I've tried to use the search feature to find serial number information without any luck. What I do know is it's a Fairbanks Z 1 1/2 HP w/a Bosch mag. Number stamped on top of hopper is 55887. Looking for year and any other information that would help me purchase the right manuals for this engine. Plan on going through it and just clean it up and refrain from a repaint. Looking to have an original example of a functional engine. Thanks, Dave
Old 10-03-2009, 10:30:11 AM
Dan Baalman Dan Baalman is offline
Default Re: Fairbanks serial number question
Wendel"s note book lists it as a 1923 model.
The Following User Says Thank You to Dan Baalman For This Post:
Old 10-03-2009, 10:31:15 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Go check your serial number again. It should have a 6 digit serial numer.
Denis Rouleau
The Following User Says Thank You to Denis Rouleau For This Post:
Old 10-03-2009, 10:40:44 AM
Wow, That was quick. Thank you. I'm pretty sure it was a 5 number serial.
Old 10-03-2009, 02:58:34 PM
Gary Pflum's Avatar
Gary Pflum Gary Pflum is offline
The number you are missing is probably on the end of the number. It would still be a 1923. There should be 6 digits for the engine that you discriped.
Old 10-03-2009, 03:47:13 PM
[QUOTE=Gary Pflum;451145]The number you are missing is probably on the end of the number.QUOTE]
But the missing digit could also be at the beginning of the number and then the year of manufacture will be different.
Old 10-03-2009, 04:38:29 PM
Here is a 1919 ad showing a F-M "Z" with a Bosch AB-33 magneto.
Old 10-04-2009, 08:51:04 PM
Thanks again everyone. I'll be picking up this engine at the end of this week. The serial will be looked at closer then. Maybe the mystery will be solved. Another question is about the Wendel's notebook, is that info found on the web somewhere also?
Old 10-09-2009, 08:04:26 PM
The sixth digit was found. 558870 is the serial number. Still wondering if Wendel's info is available online. Thanks again, Dave
Old 10-09-2009, 09:51:56 PM
Bill Bill is offline
This site might help.
http://www.oldengine.org/members/die...banksMorse.htm
The Following 3 Users Say Thank You to Bill For This Post:
Fairbanks Morse N serial number Doug Kimball Hit & Miss Gas Engine Discussion 15 07-30-2007 04:13:22 PM
fairbanks serial number earniemanson Hit & Miss Gas Engine Discussion 1 09-25-2006 08:09:15 AM
Fairbanks Morse serial number ? Anthony VA Hit & Miss Gas Engine Discussion 3 07-27-2006 10:55:12 PM
Fairbanks Morse serial number ? Anthony VA Hit & Miss Gas Engine Discussion 1 07-27-2006 10:34:44 PM
Fairbanks Serial Number Locations ?? Jonathan Widelo Hit & Miss Gas Engine Discussion 1 09-22-2005 01:56:29 AM
