Economy 1 1/2hp not running
this thread has 6 replies and has been viewed 1211 times
Old 10-06-2009, 08:27:30 PM
jameslee jameslee is offline
Default Economy 1 1/2hp not running
I have an economy 1 1/2hp it will firer for about 3-5 times and than die, i have never had it running for more than about 30 seconds. It has good spark and is getting gas. Any advice would be helpful Thanks
Old 10-06-2009, 09:01:28 PM
Tony Page's Avatar
Tony Page Tony Page is offline
Default Re: Economy 1 1/2hp not running
Sounds like a fuel problem,(you say the spark is good). If the exhaust is black you're too rich. If it sounds weak or pops you're too lean. On a new engine I start at 1/4 turn and go from there. Also make sure the check valve is working. Just a guess, Tony
PS: Some like to run with the choke partially on.
Old 10-06-2009, 10:30:34 PM
Chris Steffen Chris Steffen is offline
I had a similar problem with an engine of mine. It sounds like a fuel issue. If it starts again after it quits, more than likely it is not getting enough fuel. If it is troublesome to start after it dies it is probably flooded.
Old 10-07-2009, 07:54:27 PM
Doug Hanneman's Avatar
Doug Hanneman Doug Hanneman is offline
I agree it is probably the fuel supply. I would just remove your fuel line and check valve, clean the check valve and make sure it operated smoothly because it can look ok but still be sticky, check the line to make sure it is open and put all back togeather. Good luck.
Old 10-08-2009, 05:06:25 PM
Smile Re: Economy 1 1/2hp not running
Thank you guys for the help hopefully i can get the engine running Thanks again James
Old 10-08-2009, 07:43:09 PM
Chuck Ostrander Chuck Ostrander is offline
You did not say what model, I have a little 1 1/2 HP model N. I could get it to fire, but not run. Ended up I had to reduce the size of the fuel line and then it would run just fine.
Old 10-09-2009, 05:01:13 PM
Its an Economy 1 1/2E
1 1/2 H.P. Economy running on propane Fred Van Hook Hit & Miss Gas Engine Discussion 5 12-25-2007 10:15:43 PM
Got the 1AJ running Bob E Onan Generators 4 11-13-2007 12:24:43 PM
Got it running.......... Rich Martz Hit & Miss Gas Engine Discussion 4 11-04-2007 10:23:11 PM
Running vs. non-running engines Chris Kirk Antique Engine Archives 19 12-22-2002 08:02:12 AM
my LA keeps running away! NICK Antique Engine Archives 4 05-12-2001 01:03:16 PM
