5 HP Fairbanks style B governor assembly?
this thread has 10 replies and has been viewed 1523 times
Old 10-10-2009, 10:06:41 AM
Big Diesel Big Diesel is offline
Default 5 HP Fairbanks style B governor assembly?
Hey fellows I have a 5 hp fairbanks style B and the gonernor bracket has been demolished. It has a very big cam gear and I haven't counted the teeth yet but wondered if since the 3 hp and 6 hp Z used the same bracket if this none might too. I'm very greatful for any help or info at all on this matter.
Thanks, T.A.
Old 10-10-2009, 12:25:28 PM
Ed Deis Ed Deis is offline
Default Re: 5 HP Fairbanks style B governor assymbley???
Yes-Everything concerning the cam/gov brac assy. is the same.
Main differences that won't interchange with a 3HP are cyl block, piston, and head. (4 3/4" cyl bore for 5HP). I'm not sure but the rod bearing is different that a 3HP so that changes the diam. on the crankshaft but I think a 3HP rod would work just by changing the bearing size. I also think the main bearings are the same but to lazy to get my part books out or go out back to check this out. Ed
The Following User Says Thank You to Ed Deis For This Post:
Old 10-10-2009, 10:05:14 PM
vern0n's Avatar
vern0n vern0n is offline
Ed has a good memery. The piston is bigger. The rod journal is bigger but the mains are the same as a 3hp, and the valves are bigger. The governer assembly is the same for the 3, 5 and 6hp engines. The 5 hp is kinda rare. Is yours screen cooled or hopper cooled? Most I have seen are screen cooled.
The Following User Says Thank You to vern0n For This Post:
Old 10-10-2009, 10:28:33 PM
Byron Roberts's Avatar
Byron Roberts Byron Roberts is offline
Default Re: 5 HP Fairbanks style B governor assembly?
can you measure the flywheels.. seems they are diffrent size's..I.m on dial up..but heres a video... http://s40.photobucket.com/albums/e2...t=IM000358.flv ..B,
The Following User Says Thank You to Byron Roberts For This Post:
Old 10-10-2009, 10:57:29 PM
Thanks so much guys, mine is hopper cooled and is all there except the bracket is in 3 pieces. I just ordered one off flea bay but it has helical or slanted cut gears but all mine are still good I think. Soooo I hope I can just swap everything over.
Old 10-10-2009, 11:06:39 PM
Big deisel..ed woulds be the guy to talk to..B,
Old 10-10-2009, 11:13:10 PM
Hey Byron, you say talk to Ed. Do you mean for parts or for info or both? Thanks so much for all the help from everyone, I'm new here and I'm really enjoyin this!
Thanks, T.A.
Old 10-10-2009, 11:27:06 PM
David M. Lyon's Avatar
You Shoulda' looked in your own "Back yard" first!...Oh well, if you've already ordered one....
The Following User Says Thank You to David M. Lyon For This Post:
Old 10-10-2009, 11:30:39 PM
Thanks, T.A.
i'm sure ED has all the info you need..ED runs hitmiss enterprises..click on the top bar..Sponsors...B,
Old 10-10-2009, 11:32:38 PM
Hey thanks David, I saw it on there and it was in great shape and I snagged it for 50 bucks so I just got it. If I run into some more stuff I'll sure hit you up though.
Thanks, T.A.
Old 10-11-2009, 08:59:47 AM
Good price, if it's in good shape.
Fairbanks-Morse Z Style D governor problem revisited. JBailey Hit & Miss Gas Engine Discussion 12 12-22-2014 07:47:54 AM
Please help with B&S throttle return spring/governor linkage assembly. wally3692000 Small Air Cooled Gasoline Engines 4 09-03-2008 01:46:59 PM
Fairbanks burner assembly Gary Springer Hit & Miss Gas Engine Discussion 0 06-03-2008 09:20:19 PM
Fairbanks-Morse Z Style D governor problem. JBailey Hit & Miss Gas Engine Discussion 3 01-17-2006 12:02:31 PM
Stover CT-1 Governor Assembly Jim H. Antique Engine Archives 1 05-29-2003 08:18:11 PM
