Sinking Engines
this thread has 4 replies and has been viewed 2355 times
Old 10-11-2009, 11:11:21 PM
Steve Barr's Avatar
Steve Barr Steve Barr is offline
Photo Sinking Engines
Saturday, while at the show, I spotted that Joe had a problem....His 4hp McVicker Gearless engine was also having a problem....I had dug itself a hole and was sinking like the Titanic....Well, You cannot waste a good photo opportunity.... Soon, the problem was fixed and the engine was once again happy on level ground...
ID:	64690   Click image for larger version
ID:	64691   Click image for larger version
The Following 6 Users Say Thank You to Steve Barr For This Post:
Old 10-12-2009, 08:25:26 AM
Jerry Christiansen Jerry Christiansen is offline
Default Re: Sinking Engines
Hi all,
That is one method to set your engine in place when you forgot to bring a block.
Later,
Jerry Christiansen
Old 10-12-2009, 10:30:35 AM
Brian Triebner's Avatar
Brian Triebner Brian Triebner is offline
If you've ever tried to lift a 4 Hp McVicker you'll know why it was sinking...
Old 10-12-2009, 03:00:43 PM
Ray Cardoza's Avatar
this is why i use wood blocks under mine so they dont sink
Old 10-12-2009, 09:19:50 PM
Steve Barr's Avatar
You are correct. I helped Joe move that engine at another show as well and it settled down into the ground nicely there too, but not this bad....The listing was pretty noticeable.... I think Joe was saying it weighs around 1250 lbs.
The problem was corrected by using 4 boards under the wheels...lifting via a handiman jack. It also seemed to rock less on the boards....
Good Engines and Bad Engines Mark Thompson Steam Stationary Engines, Traction Engines 75 11-27-2009 08:45:32 PM
Sinking float, carby troubles, bad gasoline Mac Leod Hit & Miss Gas Engine Discussion 3 11-13-2007 02:38:13 AM
That Sinking Feeling on crippled parts Ed Deis Antique Engine Archives 14 11-14-2003 08:53:35 PM
