Hercules governor question
this thread has 2 replies and has been viewed 1262 times
Old 10-12-2009, 09:39:10 AM
Chris F. Morris Chris F. Morris is offline
Default Hercules governor question
Just got my first hit&miss running! Governor will not open to hold exhaust valve open at low rpm for that hit&miss sound think i need a lighter gov.spring,if so what spring do i need?No gov. parts are sticking. Motor is 3 1/2 HP S. Thanks
Old 10-12-2009, 10:50:56 AM
Skip Landis Skip Landis is offline
Default Re: Hercules governor question
just go with something lighter than you have & work down till you get the speed you want. skip
The Following User Says Thank You to Skip Landis For This Post:
Old 10-12-2009, 11:25:40 AM
R. Kern's Avatar
R. Kern R. Kern is offline
Read the reprints from GEM that Glenn Karch wrote..good ideas on setting up the engine to run slow as well and just good all around info..Some of the governor assemblies have a spindle that is in several parts including a small ball...if you take the rod out to change the spring be careful in case yours has the segmented rod...easy to drop the ball..as they say.
Link here to the Hercules web site:
http://www.herculesengines.com/hercules/default.htm
The Following User Says Thank You to R. Kern For This Post:
GAC governor question Isaac-1 Onan Generators 7 12-28-2008 06:21:38 PM
Question about the governor on the M's Ray Cardoza Hit & Miss Gas Engine Discussion 7 11-15-2008 05:54:57 AM
Hercules ZXB Motor- governor or parts KBach1021 Generators & Electric Motors General Discussion 6 07-28-2008 08:17:04 AM
Hercules governor gear Russell M Hit & Miss Gas Engine Discussion 2 05-28-2008 08:38:49 PM
Governor troubles on my Hercules Mac Leod Hit & Miss Gas Engine Discussion 3 05-14-2008 08:26:32 AM
