Go Back   SmokStak > SmokStak® General Discussion > Computer, Camera and ISP Problems
Computer, Camera and ISP Problems Solutions for accessing and using the SmokStak® boards. Posting pictures, preventing viruses and solving internet service provider problems.
Battery Charger
this thread has 5 replies and has been viewed 4590 times
Old 07-27-2010, 09:13:42 PM
Jerry B Jerry B is offline
Default Battery Charger
Can someone help me find a part for my charger ,I think they are power transistors the part no. S838 I need two of them
Old 07-28-2010, 02:30:55 AM
xplor xplor is offline
Default Re: Battery Charger
What brand is the charger?
Old 07-28-2010, 05:50:27 PM
It is a Diehard Model 200.71223 & on the parts they both have the same no. S838 and 3G021, They look like a power transistor, Jerry B
Old 07-28-2010, 06:49:21 PM
BGunn BGunn is offline
Are these on the heat sink? If yes then they are SCR's not transistors. Just look at the chargers rating and locate the output from them, this will determine the anode and cathode the other is the gate (control). Pick up a couple that match yours and go a little higher in current rating. For most of these chargers they don't use sensitive gate or any other peculiar ratings so a general rating should cover it. What happened to yours, they generally short.
Old 07-28-2010, 06:55:55 PM
JohnCarter JohnCarter is offline
The Sears Parts online lists the module as "SCR Control Module" (no longer available) so the chips may be SCR's (silicon controlled rectifier, sometimes called a thyristor).
If I could see the board, I might be able to suggest a replacement...
A quick online search didn't find a reference to either part number.
John
Old 08-09-2010, 07:27:23 AM
ListerDiesel's Avatar
The Japanese leave out the front letter occasionally, try a 2SD838, that is a Sanyo transistor.
Peter
JB3CR 7.5 kw Battery Charger Bob E Onan Generators 5 12-17-2009 11:10:44 AM
Onan battery charger Joseph Onan Generators 2 10-28-2009 03:13:24 PM
48v battery charger. envelopes2007 Onan Generators 3 01-06-2008 01:33:17 PM
Battery Charger Thingie kennyo Hit & Miss Gas Engine Discussion 2 12-15-2006 07:25:20 AM
1920's Battery Charger ? Dean Suhr Generators & Electric Motors General Discussion 2 01-27-2004 02:42:36 PM
