Help! What is this 1920`s tractor?
this thread has 10 replies and has been viewed 3130 times
Old 08-03-2010, 04:50:00 PM
RustySteele RustySteele is offline
Default Help! What is this 1920`s tractor?
I can`t find any info on this anywhere. It is missing the engine, which I also need to know what it was. The engine powers the upper shaft, which is chain drive to the lower shaft and clutch by the gear box in the front. It looks to have a forward and reverse transmission, which drives a cut down Ford Model T rear end. The drive wheels are 31" diameter, and the wheels are only 19 1/2" outside width. Parts of it look to be homemade, but it has too many special castings and is too well made to not be factory made. I would love to hear from ANYONE who has any info on what this could be and what the correct engine is for it. Thank You!
Last edited by Mike in NC; 08-03-2010 at 05:44:26 PM. Reason: deleted dead photo links
Old 08-03-2010, 04:57:55 PM
Default Here are the pictures of my tractor in the previous post.
I hope the pictures come through this time.[IMG][IMG]100_9086[/IMG][/IMG]
---------- Post added at 04:57 PM ---------- Previous post was at 04:55 PM ----------
I didn`t think that I was this much a computer illiterate, but if anyone has any suggestions on how to get 48Kilobyte pictures on here, please let me know!
Old 08-03-2010, 05:45:16 PM
Mike in NC's Avatar
Default Re: Here are the pictures of my tractor in the previous post.
Check PM's.
SmokStak Member #28
The Following User Says Thank You to Mike in NC For This Post:
Old 08-03-2010, 07:12:53 PM
Heller D. Davis Heller D. Davis is online now
Default Re: Help! What is this 1920`s tractor?
A picture would be worth a lot. Probably could get some help then.
The Following User Says Thank You to Heller D. Davis For This Post:
Old 08-04-2010, 09:08:16 AM
badboy1950 badboy1950 is offline
Photo Re: Help! What is this 1920`s tractor?
i will try to post rustys photos
Dan
ID:	84301   Click image for larger version
ID:	84302   Click image for larger version
ID:	84303   Click image for larger version
The Following User Says Thank You to badboy1950 For This Post:
Old 08-04-2010, 09:51:01 PM
Dave Wight Dave Wight is offline
there is a possible chance that you may have one of the BEEMAN garden tractors made in Minneapolis,Mn yours may be the jr,it used the b/s2.5x2.5vertical 1cylinder, carb was a tillotson. hope tis helps lots of luck. dave
The Following User Says Thank You to Dave Wight For This Post:
Old 08-04-2010, 10:11:57 PM
Thanks to Mike and Dan for offering to get my pictures posted! Dave, I also thought at first that it may be a Beeman Jr., but the drive train is entirely different and my engine sits in the back, not the front like the Jr. I hope someone can put a name on this, it is one of the weirder tractors I have and I`d love to know what I have, and what engine i have to look for to go in it. Thanks for everyone`s help!
Old 08-04-2010, 10:16:47 PM
Austen's Avatar
Austen Austen is offline
That is really neat.
The Following User Says Thank You to Austen For This Post:
Old 08-05-2010, 02:38:12 PM
the handles made with pipe and fittings, what's up with that ?
is it a home made rig ?
Dan
Old 08-05-2010, 06:03:40 PM
I`m pretty sure that it is factory made. There are a lot of castings in this, such as some of the pipe handle brackets. Unless the farmer had a pattern maker, foundry, and tinsmith at his disposal, I would say that it isn`t homemade. It looks like it would have been an expensive tractor in it`s time, which might explain why there aren`t many around.
Old 08-10-2010, 07:56:30 PM
rusty if u ever get it figured out as to what breed that tractor is let us know. thanx dave
Olin Garden Tractor (1918, 1920) Russell Collins Garden Tractors and Mowers 2 01-18-2017 02:27:55 AM
JT Crawler tractor Cleveland, OH 1920? Rene Elliott Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 12-07-2011 11:05:43 PM
What is a 1920 IHC 6hp worth? wydiver Hit & Miss Gas Engine Discussion 10 03-02-2009 08:24:19 PM
Parts for 1920 IHC M 6 HP PCotton Hit & Miss Gas Engine Discussion 2 11-16-2006 05:30:43 PM
1920 Minneapolis 20hp steam tractor Blake Hancock Steam Stationary Engines, Traction Engines 3 09-07-2003 07:57:04 PM
