Little crawler teardown
this thread has 0 replies and has been viewed 1346 times
Old 11-26-2010, 01:09:21 PM
wilson Ross wilson Ross is offline
Default Little crawler teardown
So far teardown is or was going well (see pic) one track roller was locked up years ago by a rock now is really flat on one side. A little gear box from the out put side of the transmission that supplies power to the winch and the rear end is broken. will try to find numbers to try and find a new one or have this one fixed.
In pic 0329 that is the gear box dose anyone recognize it ????
ID:	93496   Click image for larger version
ID:	93498   Click image for larger version
ID:	93500   Click image for larger version
The Following 2 Users Say Thank You to wilson Ross For This Post:
Onan DJE teardown pics attached revg62 Onan Generators 10 01-06-2010 11:23:00 PM
Onan 2.8KV Teardown to remove carb - help! Orie Onan Generators 1 08-06-2009 06:54:27 PM
Cam timing after teardown gruby26 Small Air Cooled Gasoline Engines 3 01-18-2009 09:21:11 AM
Tecumseh H30 teardown and overhaul squarend Small Air Cooled Gasoline Engines 9 05-10-2008 11:35:27 PM
Teardown to remove sludge? Orrin Iseminger Antique Engine Archives 8 01-05-2000 08:41:29 PM
