Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Adapting a Maytag Mod 82 Pull Rope Start
this thread has 1 replies and has been viewed 1734 times
Old 03-13-2011, 11:18:03 PM
Francis Francis is offline
Default Adapting a Maytag Mod 82 Pull Rope Start
The person that owns the Maytag Model 82 that I am restoring wanted an easy way to start the engine. Fortunately, this engine still had the flat belt pulley. It was decided that a rope pull could adapted using the pulley. Two flat round plates (1¼" larger in diameter than the diameter of the pulley) were made from scrap sheet metal. 3-¼" holes were drilled in each plates to corresponding to the position of the pulley spokes. A slanted slot (to attached the pull rope) was cut in the plate that was to install on the outer side of pulley. The pulley edges were machined to insure a flat parallel surface to mount the round plates. See attached picture.
Next, the two flat round plates were mounted on either side the pulley and held together with the 3 ¼" diameter bolts with the pulley being sandwiched between the two round flat plates. The bolts were positioned so that they would contact pulley spokes. See attached picture with the assembled pull rope pulley adapter mounted on the engine.
ID:	102483   Click image for larger version
The Following 2 Users Say Thank You to Francis For This Post:
Old 03-14-2011, 07:42:58 AM
Andrew Mackey Andrew Mackey is online now
Exclamation Re: Adapting a Maytag Mod 82 Pull Rope Start
If you have the original flat belt pulley, wrapping a leather clothing belt around the pulley works fine, with out making something up.
Army Surplus generator 2A016- convert rope to recoil start? grady Garden Tractors and Mowers 13 10-07-2013 05:44:13 PM
Pull start reinstall Johnnyboy Small Air Cooled Gasoline Engines 4 01-09-2011 05:11:00 PM
Rope Start Round Head FH Briggs Junkologist Small Air Cooled Gasoline Engines 4 07-26-2009 07:02:17 PM
Briggs FH slant fin rope start Jim Sherman Small Air Cooled Gasoline Engines 9 04-07-2006 03:31:59 PM
Briggs FH rope start date? Jim Sherman Hit & Miss Gas Engine Discussion 1 01-10-2006 02:41:11 PM
