Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Onan Generators
Gasoline Conversion to Propane (Onan)
this thread has 43 replies and has been viewed 9724 times
Old 11-29-2010, 08:02:20 PM
Cruiser Cruiser is offline
Default Gasoline Conversion to Propane (Onan)
7.5 JB FJ
Serial# J930521510
How much trouble & how much $$ am I Talking ball park for a conversion. Thks in advance to all the experts!!
Old 11-29-2010, 10:36:50 PM
Gunny Gunny is offline
Default Re: Gasoline conversion to Propane
Talk to these folks.
http://www.mouldensupply.com/
Cost will depend if your existing carburetor is
already set up for dry fuel.
Old 11-30-2010, 12:40:18 AM
bobbyz72 bobbyz72 is offline
Default Re: Gasoline Conversion to Propane
Drill a hole in the carb and a $50 demand regulator, now you have a trifuel.... done..
Old 05-03-2011, 10:44:20 PM
Jim McIntyre's Avatar
Jim McIntyre Jim McIntyre is online now
I guess I'll revive this old thread, since I have pretty much the same question.
The set is a 7.5JB FL sn I930519818 Spec 16581D, gasoline only, as far as I know. (One of the Toldeo sets.)
I understand about fuel controllers (garretson KN?) But does anyone have a picture of the carb modification needed? (I don't need "tri fuel" - just natural gas.)
Old 05-03-2011, 10:52:28 PM
"Picture" you sending me your gasoline carb and fuel pump.
I'll send you a KN and gas carb.
Old 05-03-2011, 10:55:12 PM
That works for me, Wayne. - I'll be in touch next week when this thing shows up...
Old 05-04-2011, 01:53:26 AM
BTPost's Avatar
BTPost BTPost is offline
Talking Re: Gasoline Conversion to Propane
Wow, Hey Guys, Such a Deal, I have for you, One Time Only, Today.... Nice to see it, when a "Plan" comes together..... Good Go'en....
Bruce in alaska
Old 05-04-2011, 07:28:49 AM
MBB MBB is offline
Hey Bobby did you ever convert a JB and if so where did you drill the carb? I cant see a good place to do it. I want to keep th ability to use gas.
Old 05-04-2011, 07:52:20 AM
iceman iceman is offline
I have done several converssions to gasoline carbs and they work Fine. I have bought some demand Regulators on ebay. and only have to install a Ball Valve between the regulator and carb to adjust the Fuel. The ball valve acts like the "Main Jet" in Gasoline carbs. See photos of a Carb that I just Converted.
Kieth
ID:	106036   Click image for larger version
ID:	106037   Click image for larger version
ID:	106038   Click image for larger version
The Following User Says Thank You to iceman For This Post:
Old 05-04-2011, 08:43:43 AM
K D Redd K D Redd is offline
I have also done several. I strive to NOT destroy the carbs ability to still be usable with gasoline. Search for my post and you will find pictures.
P.S. When you make a conversion to either LP or NG while not destroying the carbs ability to use gasoline you have a Tri-Fuel system.
Kent
Old 05-04-2011, 11:00:56 PM
Kent,
I found your post on the CCK, is there also one on a JB?
Iceman,
Thanks. Is that a JB carb?
Old 05-04-2011, 11:21:43 PM
Watch the ENTIRE video and see if thats the same carb you have....You can see the brass plug i put into the drill and taped hole.... i can send you close up pictures if it is.
http://www.youtube.com/watch?v=CPFmwUNYEQA
The Following User Says Thank You to bobbyz72 For This Post:
Old 05-04-2011, 11:38:50 PM
MBB MBB is offline
Bobby thats looks similar not identical but the location you drilled seems like it could work. My choke is mounted to the other side and I cant see the float bowl. Id be interested in a picture if you have it. Check PM for email.
Old 05-05-2011, 08:14:39 AM
Jim, No the carb in the photos is from a Military MEP-017a genset that I just converted to LP.
Kieth
aka: iceman
Old 05-05-2011, 09:14:35 PM
c east c east is offline
Where did you get the nice muffler?.....Where did you get the air cleaner cartridge?
Charlie
Old 05-05-2011, 10:21:43 PM
With that set up, i get 6.5+ kw on gasoline, and about 6kw on natural gas, i know your working on a jb, but id say you should be even better off..
ID:	106138   Click image for larger version
ID:	106139   Click image for larger version
ID:	106140   Click image for larger version
Old 05-05-2011, 10:23:46 PM
Default Re: Gasoline Conversion to Propane (Onan)
You know you can move the choke to the other side.... mine was on the other side also...
Old 05-06-2011, 12:15:47 AM
mixdenny mixdenny is offline
Bobby, I am curious about your drilled carb. It appears to be the same basic carb I have on my 6.5 NH, mine is the factory natural gas setup. The factory uses the long horizontal boss to bring in the gas. On your third photo it has a bright white something sticking out of the place the gas would be brought in, just wondered what it was.
Dennis
Old 05-06-2011, 07:16:54 AM
MBB MBB is offline
Thats teflon tape from the connection where the gasoline connection is.
Old 05-06-2011, 08:40:17 AM
Looks to me like a white nylon 90 degree fuel line fitting that has been used on small engine fuel systems for decades.
A POINT on Teflon tape, ALWAYS! start your tape ONE THREAD back from the end of the fitting to prevent pieces of tape entering the flow stream of what ever the fitting is carrying. Years ago HOT ROD Mag. gave T tape a bad name because a NAME racer had to shut his car down at the starting line because of a flooding carb. The cause of the flooding carb was a piece of T tape under a float needle.
I also know one Hydraulic parts supplier that IF they find out that T tape was used to assemble a system they WILL void the warranty on their parts. They are OK with Teflon paste. You can use T tape IF as I said above to NOT cover the first thread of the pipe thread fitting.
The then-now company I have been posting that build fuel pump kits for for older equipment also does not like ANY Teflon sealant because they claim it will cause one to screw the fitting in OLD pump body to far causing the irreplaceable pump bodies to be destroyed from the fitting boss cracking.
T tape and RTV gasket make share ONE thing: More is not necessarily better. Use either intelligently and you will NOT have a problem.
Kent
The Following User Says Thank You to K D Redd For This Post:
Onan 15 OJC-3CR NG to Gasoline Carb Conversion BallyOnan Onan Generators 6 11-28-2010 01:25:28 PM
Onan JC 12.5Kw w/ new Propane conversion will not run... Grizzly Hill Onan Generators 6 11-09-2010 09:54:47 PM
Onan CCK conversion to propane biggerpatterson Onan Generators 11 10-24-2010 08:30:21 PM
Natural gas conversion to propane or gasoline gerald m Onan Generators 5 01-04-2010 11:49:25 AM
12.5 JC 3CR - Gasoline to Nat Gas conversion D. Cowart Onan Generators 4 08-09-2006 12:31:30 AM
