Techumseh HH120 Solid State Ignition Replacement in a Bolens 1257
this thread has 1 replies and has been viewed 196 times
Old 08-17-2019, 06:00:44 PM
bigGURN's Avatar
bigGURN bigGURN is offline
Default Techumseh HH120 Solid State Ignition Replacement in a Bolens 1257
The Solid state ignition was found to be bad on the HH120 Techumseh in this Bolens 1257 (a common issue). I built a replacement using scrap aluminum, a GM HEI ignition module (from a early 1980s GM distributor), a 2000 Ford F150 rear differential antilock brake sensor (used as a magnetic pickup, triggered by the stock trigger pins on the flywheel) and a ignition coil from a 1978 Ford F150. $12 in parts from the local you pick auto part salvage.
Works well. The owner (my 10 year old) couldn't be happier!
The Following User Says Thank You to bigGURN For This Post:
Old 08-18-2019, 01:11:11 AM
bigGURN's Avatar
Default Re: Techumseh HH120 Solid State Ignition Replacement in a Bolens 1257
I did a write up per the request of a few users. I have uploaded it as a pdf document to make it easy to download and use.
File Type: pdf Tecumseh Solid State Ignition Conversion.pdf (234.3 KB, 21 views)
solid state ignition module wires thorr Wisconsin Engines 1 05-14-2015 08:22:15 PM
Solid-state ignition Phil P Magnetos, Ignition Coils and Spark Plugs 7 03-03-2011 02:30:43 PM
HH120 Solid state Sky Garden Tractors and Mowers 3 05-17-2010 08:54:49 AM
Solid State Ignition Class of 64 Garden Tractors and Mowers 12 07-12-2009 06:05:19 PM
Tecumseh Solid State ignition Sky Small Air Cooled Gasoline Engines 7 06-15-2009 02:21:05 PM
