John Deere AR engine trouble
this thread has 22 replies and has been viewed 1296 times
Old 08-19-2019, 11:09:07 PM
Default Re: John Deere AR engine trouble
Here it is.
The Following 2 Users Say Thank You to Craig A For This Post:
Old 08-19-2019, 11:48:38 PM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
Thank you both, now I know what to look for .
The Following User Says Thank You to Jack Innes For This Post:
  #23
Old 08-24-2019, 11:16:18 AM
Jack Innes's Avatar
Update, The ar is a beast to crank but after overhauling the magneto & timing it I was able to make it fire & run for a few seconds. The carb was full of rust & totally stuck - I am waiting for a kit to arrive. The throttle shaft was well worn but the housing has brass bushings that are replaceable which is a good feature.
Trouble starting John Deere 1 1/2 hp engine slade12178 Hit & Miss Gas Engine Discussion 16 07-23-2017 03:22:11 PM
John Deere G carburetor trouble Dave Wiesman Antique Farm Tractors 7 08-16-2016 08:36:13 AM
John Deere D Magneto Trouble 1929 John Deere D Magnetos, Ignition Coils and Spark Plugs 6 12-01-2012 08:11:59 PM
John Deere 1 1/2 E Governor Trouble Butch50 Hit & Miss Gas Engine Discussion 7 11-17-2011 10:43:35 PM
Mid 70's John Deere 110 trouble! Johnchukoloski Garden Tractors and Mowers 7 02-07-2010 11:36:01 AM
