trailer battery
this thread has 23 replies and has been viewed 13621 times
Old 12-09-2012, 07:58:58 PM
Steve Kunz's Avatar
Default Re: trailer battery
Hey Andy whats that thing on the trailer? lol
It looks like you have a nice set up for going to shows! Drive, haul, camp all in one.
Steve
The Following User Says Thank You to Steve Kunz For This Post:
Old 12-10-2012, 07:22:26 AM
AndyG's Avatar
AndyG AndyG is offline
[QUOTE=Steve Kunz;848592]
Hey Andy whats that thing on the trailer? lol [QUOTE]
I told the guys at Boonville, IN that it was a return flue Keck-Gonnerman to get into their show.
Steve
That was the idea Steve. After seeing the flywheel engine guys travel in comfort with their motorhomes I decided to try it with a steamer. I would rather stay at the showgrounds than a motel anyway.
The Following User Says Thank You to AndyG For This Post:
  #23
Old 12-10-2012, 11:11:02 AM
Elden DuRand's Avatar
I never liked the "isolators" (thing with big lugs and heat fins) because,
1: They have diodes in them which drop about a half volt, never allowing the batteries they charge to fully charge.
2: I took a blown one apart once and, although it was rated at 100 amps, the diodes were no larger than any ten amp diode I've ever seen. In other words, cheap!
What I've done in the past is to use a relay to isolate the batteries. On one camper, I energized the relay with a circuit with a delay that looked to see if the oil pressure light was lit. That way, the engine would be running before the relay closed.
If you're really hinky about overloading something from a dead trailer battery or heavy loads, simply buy a box or two of 12 volt brake/tail light bulbs and parallel 'em then hook the string in series with the charging line. The number of bulbs depends on how much current you want the line to draw at maximum load. The bulbs, when not lit, are like a piece of wire. When the current gets high enough to heat the filaments, the resistance rises to limit the current. Works for me!
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
  #24
Old 12-13-2012, 11:22:37 PM
AndyG's Avatar
Thanks Elden, The possibility of the dead or, nearly dead trailer, battery is my main concern. I may put the light bulb trick to work.
they will never fit on the trailer Lee Werth Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 01-04-2006 07:31:32 PM
So now where do I go for a new trailer Steve Gerot Antique Engine Archives 11 03-31-2003 11:52:08 PM
What about your trailer? Tim Claremont Antique Engine Archives 19 02-19-2002 11:00:43 AM
