Centaur Tractors
this thread has 24 replies and has been viewed 9086 times
Old 10-10-2016, 12:10:06 PM
Norm S Norm S is offline
Default Re: Centaur tractors
Does anyone know of a serial number list exists? I'm looking at a KV and have no idea what year it is. # 53696
Thanks!
Old 10-10-2016, 02:41:24 PM
Doug Tallman Doug Tallman is offline
The 536 in the serial shows it to be built in May of 1936. It was the 96th K series tractor made.
---------- Post added at 02:41:24 PM ---------- Previous post was at 02:38:25 PM ----------
Originally Posted by Gomer Buehring View Post
I will check the serial # the old fellow was 102 when he passed and sharp as a tack! He had a small truck garden and used the 2G to plow, plant, and cultivate his potatoes!
Gomer, Did you ever check the serial number on this tractor? Do you have the bill of sale?
Old 10-22-2018, 10:38:25 AM
bATL645 bATL645 is offline
Originally Posted by Smokzalot View Post
We got a couple of em'. fun little tractors and they always draw a crowd. if you are thinking of buying it there are couple things to check before you do. Make sure the exhaust manifold is not cracked...especially on the flat head engine. Also, check the oil in the trans. for water as they did not seal well behind the shift tower. Finally, check the oil in the final drives to the wheels. These were prone to leak because the fender was used to seal the outer half of the case ....drip....drip.. One last thing...just fyi to any other centaur owners, I'm working on trying to get a foundry to make us a manifold, let me know if you would like a copy. thanks JE
do you still have centaur tractors the reason i am asking is i need a distributor... lance 727 504 6072
The Following User Says Thank You to bATL645 For This Post:
  #24
Old 10-22-2018, 01:44:52 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
The distributor on our KV was missing when we got it. Not finding an original small cap unit, I found that the unit from a John Deere 45 combine motor will fit right in and parts are easier to find.
The Following 2 Users Say Thank You to FWurth For This Post:
  #25
Old 06-13-2019, 10:24:19 PM
lostsole69 lostsole69 is offline
I have a 1936 KV I would like to know id there will be a exhaust manifold available and wheel seals
---------- Post added at 09:24:19 PM ---------- Previous post was at 09:23:04 PM ----------
Originally Posted by Matt L View Post
I have a 38 centaur. Been sitting outside for a long time. I saved it from the scrap man. Mostly complete. Bad manifold. Its for sale fixer up or use for parts.
price?
New Way Engine on Centaur G PGH Garden Tractors and Mowers 9 08-27-2018 11:05:29 PM
Centaur HBurk Garden Tractors and Mowers 7 11-04-2014 09:07:09 AM
Centaur HBurk Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 11-01-2014 09:28:41 PM
Westbury Centaur. Manorfarmdenton Scale Model Engineering 9 09-27-2012 05:58:17 AM
Centaur and Red E videos Tim B Garden Tractors and Mowers 11 10-12-2008 11:10:14 PM
