Ford 8N saga, Part II - Starts, but won't keep running
this thread has 28 replies and has been viewed 10627 times
Old 08-10-2013, 09:29:09 PM
tirediron tirediron is offline
Default Ford 8N saga, Part II - Starts, but won't keep running
So, I got the carb issue sorted, and it now sucks up gas just fine. The tractor starts.... BUT... it won't keep running. It runs for between 20 and 60 seconds and then stops; while it is running, it seems to run just fine, sounds good. Once it's stalled out, it'll start right up again, and the same thing... over and over and over. Spraying starter fluid into the carb doesn't seem to make a huge difference so it doesn't really sound like a fuel problem to me.
I've got the timing set pretty close I think, and while it seems fine, but it won't keep running.
Old 08-10-2013, 09:37:18 PM
Culy's Avatar
Culy Culy is offline
Default Re: 8N saga, Part II - Starts, but won't keep running
Does ford tractors have a "no oil pressure" safety shut off gauge on them like our old JD 720. I remember an issue like you have and it was the oil pressure gauge malfunctioning. It would start and run good for 30-60 seconds and shut down. Start right up and repeat the whole scene over and over. Unplug the gauge wiring and ran great so put a new gauge in it and cured it good.
The Following User Says Thank You to Culy For This Post:
Old 08-10-2013, 09:49:13 PM
williamgrgn williamgrgn is offline
what year is the 8n and is it 6 volt or 12 volt and pretty sure they don't have a low pressure shut off switch
The Following User Says Thank You to williamgrgn For This Post:
Old 08-10-2013, 09:51:20 PM
Hmmm... never heard of anything that sophisticated on an 8N - didn't see it mentioned in the manual, but that doesn't mean much. Hopefully someone knows for sure.
---------- Post added at 06:51 PM ---------- Previous post was at 06:49 PM ----------
Not sure of the year as the s/n is partly obliterated, but it's a 6v, front-mount (old-style) distributor.
Old 08-10-2013, 10:28:17 PM
Jason W Jason W is offline
Sounds to me like your fuel line is blocked at the tank. It could also be the little resistor under the dash. Mine acted really odd when that went out.
The Following User Says Thank You to Jason W For This Post:
Old 08-10-2013, 10:56:36 PM
Pat Barrett Pat Barrett is online now
Change the distributor condenser.
The Following 2 Users Say Thank You to Pat Barrett For This Post:
Old 08-10-2013, 11:47:05 PM
Blocked fuel line occurred to me, but what puzzles me about that idea, is that even when put the happy=sniff to it, it still seemed to do the same thing.
Hmmm... I'll be honest, I hadn't even considered the ballast resistor. I'll check that tomorrow.
Old 08-11-2013, 12:02:20 AM
I agree, sounds ignition related if the ether whiff doesn't help. Good luck on the troubleshooting.
Old 08-11-2013, 12:08:52 AM
It's brand new, as are the points.
Old 08-11-2013, 08:38:18 AM
Mike Hole Mike Hole is online now
Try this, take a jumper wire with two alligator clips on it and connect one end to each terminal of the ignition ballast resistor.If the tractor stays running your problem has been found.
Its located on the back side of the dash board on the left if your sitting in the seat.It is a small square of black or brown bakalite with what looks kind of like a spring mounted to it and two small wire terminals.
I've replaced many over the years and the symptoms before repair are often like you describe.
You won't do any harm to the system to bypass it for a short time.
Good Luck
The Following User Says Thank You to Mike Hole For This Post:
Old 08-11-2013, 03:11:29 PM
T'weren't the ballast resistor at all. Jumpered it out, no change to the symptoms. HOWEVER, start the tractor and keep tapping on the float bowl with a 12" 1/2" extension, guess what... keeps running (at least until my arm got tired enough to stop tapping). Seems that the brand-new needle valve & seat I installed like each other just a little too much.
Does anyone have a source for needle valves without the ****ing Viton tip?
Old 08-11-2013, 03:19:28 PM
mmcdonald mmcdonald is offline
Banner Sponsor
It's not the Viton tip in itself. The USA float valves we use seem to work fine for a reasonable period of time. Granted I prefer SS myself, but the overseas rubber and the metal machining leave much to be desired. This goes for belts too. Many of these float valves wont work right out of the box and have had many of the belts breaking prematurely. Also check for the float or pin dragging or binding. Not trying to change subject with belts but the crappy rubber made me think of it. Good luck.
info@mcdonaldcarb.com
The Following User Says Thank You to mmcdonald For This Post:
Old 08-11-2013, 03:49:50 PM
Well... either the Viton needle or an improperly machined seat; when I had it apart, and held the upper assembly 'right away up', the float moved freely, but the needle valve would not drop down without a little persuasion.
---------- Post added at 12:49 PM ---------- Previous post was at 12:44 PM ----------
(nb. the float position is correct)
Old 08-11-2013, 05:47:56 PM
If the new needle has the viton tip did it come with a tiny, U shaped, clip thingy?
Viton needles are notorious for sticking in the seat....... .......so the little clip is made to engage in a groove in the needle and then hook to the float lever so the lever pulls the needle off the seat.
Old 08-11-2013, 06:26:10 PM
D'ohhhh... it's been so long since I've done one of these, I totally forgot about that little clip, and no, it didn't. Time for another call to my buddy at the pars counter!!!
Old 08-11-2013, 11:34:29 PM
Wayne Riedlinger Wayne Riedlinger is offline
Your float could be set too low or it could be rubbing the inside of the bowl causing it to not "float" very well?.
The Following User Says Thank You to Wayne Riedlinger For This Post:
Old 08-12-2013, 10:26:55 AM
The float level is bang on spec, and it seems to move freely; shaking the carb when it's dry, I don't hear any 'wrong' sounds, but I will double-check that.
Old 08-18-2013, 09:16:21 AM
rogercsi rogercsi is offline
Default Re: Ford 8N saga, Part II - Starts, but won't keep running
I have a 8n with a front mount distributor that did the same thing. I replaced the 6v Ford style coil with a remote 12V coil and change it over to a 12v system and had no further issues.
Old 08-19-2013, 12:00:55 AM
12v conversion would be nice, but it's a sentimental unit and the owner wants to keep it as original as possible.
Solved the problem; the issue was the ****ing Viton tip on the needle valve which kept sticking in the seat and there's no provision for one of those little clips to connect it to the float valve.
The Following User Says Thank You to tirediron For This Post:
Old 08-27-2013, 02:35:47 PM
dadsshop dadsshop is offline
Try cleaning out the gas tank. You may have junk in there that's blocking the gas.
Generac starts but won't stay running RoyW Generac Generators (SEARS, etc.) 13 05-07-2019 07:32:04 AM
Generac xp 6247-8 starts but will not stay running Kevin Henshaw Generac Generators (SEARS, etc.) 3 05-19-2010 05:31:38 PM
Classic-starts but wont keep running problem bowtie Onan Generators 4 03-16-2010 04:48:45 PM
Onan 6.5 NHE starts but won't stay running. dalewall Onan Generators 11 08-24-2009 02:10:41 AM
12 kw djc starts but won't stay running David Catron Onan Generators 20 09-10-2005 10:12:50 PM
