Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Lister Petter LV2 diesel engine
this thread has 3 replies and has been viewed 3177 times
Old 08-19-2013, 04:26:01 PM
diesel59 diesel59 is offline
Default Lister Petter LV2 diesel engine
Hi could anybody let me know where to find the power curve,torque curve etc.as the local model engineering club are looking to use this to build a deltic diesel,and the possible fuel consumption at 12kw thanks
Old 08-19-2013, 05:33:07 PM
Roland Hayes Roland Hayes is offline
Default Re: Lister Petter LV2 diesel engine
I can only find the data sheets for the LV1 but I suppose the figures can just be doubled for the LV2, see what you think, the PDF is too big to put on here so Private Message me an email address and I'll send it to you
Old 08-19-2013, 10:29:41 PM
moteurdelco moteurdelco is offline
a lv2 is smaller than a st or ts2; so dont expect more than 7 kw at 1800.
Old 08-20-2013, 03:43:56 AM
The main advantage of the Lister LV2 is that this engine is rated for continuous operation at 3600 rpm at which speed it will make 18 hp, (or up to 20 hp on intermittent overload), the TS and ST range Lister engines although bigger engines do not have the 3600 rpm capability of the LV so have to operate at 1800 rpm (on a direct coupled alternator) at which speed they make less power than the smaller LV engine. Personally I rate the LV2 engine very highly, for the performance its one of the smallest diesels in the older Lister/Petter range, close coupled to a short Stamford Newage alternator they make compact and powerful generating sets.
Lister Petter Diesel, compression & starting problems. LiverpoolDave Vintage Diesel and Oil Stationary Engines 11 09-13-2015 07:01:28 AM
Lister-Petter Diesel - part of genset wa5dxp Vintage Diesel and Oil Stationary Engines 4 05-12-2013 07:55:46 PM
Lister-Petter Engine FR 3 Joerg B Antique Marine Engines and Outboard Motors 3 02-15-2011 02:18:26 PM
My first stationary diesel: Lister-Petter HR3 Alyssa Vintage Diesel and Oil Stationary Engines 0 09-30-2008 05:54:26 PM
Off topic,Lister Petter 6.5 diesel Arthur Vintage Diesel and Oil Stationary Engines 2 11-18-2006 11:00:05 AM
