Serial number plate for a 35 John Deere B
this thread has 7 replies and has been viewed 2265 times
Old 03-19-2014, 10:33:43 AM
Johnny D 1837 Johnny D 1837 is offline
Default Serial number plate for a 35 John Deere B
Where can I get a new brass serial number tag made for my John Deere b? The onei have is pretty scarred up and I would like to keep this tractor as original as possible. If I can find someone who can reproduce a tag that is brass and looks factory I will have my number stamped into it
Johnny d
Old 03-19-2014, 01:34:22 PM
Dave Wight Dave Wight is offline
Default Re: Serial number plate for a 35 John Deere b
Johnny D Have you tried ,Yesterday's rides and metal works, or try John Deere its self, one of these should be able to help. good luck
Old 03-19-2014, 02:35:43 PM
ronm ronm is offline
This is the only one they show, it's not brass, but may be as close as you can come...
http://www.steinertractor.com/JDS723...r-tag-w-rivets
Old 03-19-2014, 03:34:10 PM
Brian Chester Brian Chester is offline
Try this fellow, I know he is over here in the UK but I know he does good work and am sure his work has travelled accross the pond!
www.vintagebrassplates.co.uk
The Following User Says Thank You to Brian Chester For This Post:
Old 03-19-2014, 07:09:12 PM
Phil Johnson's Avatar
Default Re: Serial number plate for a 35 John Deere B
I've had him make plates for me and his work is top notch.
Old 03-19-2014, 10:55:35 PM
thank you! i sent a message to vintage plates, Now what was the original rivit? brass or steel?
Johnny d
Old 03-20-2014, 08:54:14 AM
B.C. Cushing B.C. Cushing is offline
On my early JD A and B tractors, the rivet is steel. Keep the old plate as with JD's the serial number plate is an important part of the value. I would suggest you attach it on the tractor like under the frame where the engine sits in the frame so there is no question as to the correct serial number and it will not get separated from the tractor or lost. Good luck
The Following User Says Thank You to B.C. Cushing For This Post:
Old 03-20-2014, 09:15:11 AM
You say you want to keep it as original as possible; i would say leave the original tag on it, if it's intact & legible at all...I think your tractor is worth more that way, any repro tag is a step down, the correct police won't whine as much as they will about a 'fake" tag...Just sayin'...
The Following 2 Users Say Thank You to ronm For This Post:
'26 D John Deere serial number question Caleb Carpenter Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 05-19-2011 01:59:25 PM
John Deere A Serial Number C. Lambert Antique Farm Tractors 4 02-19-2011 11:24:50 AM
John Deere 2010 serial number. JayVickers Antique Farm Tractors 3 07-18-2010 02:09:42 PM
John Deere Serial Number Checker Farmboy1 Hit & Miss Gas Engine Discussion 5 06-08-2010 10:07:09 PM
Galloway Serial Number Plate Bob Johnson Antique Engine Archives 9 11-22-2004 07:44:23 PM
