Temporary gas tank
this thread has 2 replies and has been viewed 1414 times
Old 05-12-2014, 01:28:17 PM
Tom Lee Tom Lee is offline
Default Temporary gas tank
I recently purchased a 5 hp Economy engine that doesn't have a gas tank.Id like to test start this engine by using a temp gas tank that will be located higher than the carb. Will this work or will gas flood into the carb. I won't have an inline check valve.
Thank you, Tom Lee
Old 05-12-2014, 06:54:48 PM
John Newman, Jr.'s Avatar
Default Re: Temporary gas tank
These do not have a conventional carburetor. There is no float needle valve to shut off the flow of gas, so if the tank is above the mixer, it will run out and/or flood the engine. Tank needs to be below the mixer and a check valve in the fuel line is pretty much necessary.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 05-13-2014, 02:22:45 PM
vern0n's Avatar
vern0n vern0n is offline
I have done it the way your speaking of, but usually ends up flooding them. I used a Freon jug in the base of my 5hp Economy. No one can see it, so why not?
Nelson Bros. model N temporary ignition? Zira Hit & Miss Gas Engine Discussion 4 12-11-2013 09:20:37 PM
ideas for a temporary setup for upcoming Blizzard AndersonMillTexas Onan Generators 58 02-08-2013 09:00:45 PM
Size NG/Propane line to 7.5JB: temporary w peterson 54 Onan Generators 8 10-29-2008 01:48:59 PM
Temporary lpg hookup for testing (15.0JC) bkahler Onan Generators 17 10-02-2006 10:41:48 PM
Gib Key - temporary fix Paul Spence Antique Engine Archives 4 09-06-2004 01:12:46 AM
