Paint Shop
Paint Chipping
this thread has 2 replies and has been viewed 1869 times
Old 09-28-2016, 07:20:46 PM
overdriver overdriver is offline
Default Paint Chipping
I have prepped 2 motors
removed rust and ospho coated the cast iron, etc
then used self etching primer
then top coated with rustoleam enamel paint
and when I can baked it in an oven for a short time
as I heard this was the best way to get a durable harder finish
I have had multiple chipping with doing this
I realize I am not going to stop all accidents etc .
but seems I haven't got a harder finish
did I miss a step or what am I doing wrong ???
thanks
Old 09-30-2016, 05:39:46 PM
Scotty 2 Scotty 2 is offline
Default Re: paint chipping
Hello
I've sometimes found that the harder the paint the easier it is to chip. Sometimes it seems to be brittle and chips quite easy, especially on the squarer 'edges' of castings like hopper corners. A little tap and a big chuck of paint is off.
Cheers Scott
The Following User Says Thank You to Scotty 2 For This Post:
Old 08-22-2018, 09:57:33 AM
PaintChemist PaintChemist is offline
Default Re: Paint Chipping
A couple of things to be aware of. First, Rustoleum Protective Enamel sold in hardware stores is a linseed oil based paint product. That's not a bad thing but you have to understand its limitations. Linseed oil is commonly used in many paints because the flax oil polymerizes into a nice robust paint film. The technology has been around for nearly two thousand years. Linseed oil based paints are softer and more flexible than an alkyd, epoxy or urethane type of paint. When you "baked" your paint in the oven, you took away the paint's natural performance properties by making it brittle. Adding heat will never make a Rustoleum-like paint harder. You can add some heat to speed dry time but never exceed 100F for more than an hour or two. Oil based paints will get harder over time as the flax oil polymerizes. Rustoleum has an Industrial line of products and I would suggest using those coatings if you want a harder finish. Any brand of alkyd, epoxy or urethane will give you a harder, more durable finish. Cast iron is a very difficult surface to successfully paint with longterm performance. I would recommend using an epoxy primer on squeeky-clean cast iron. Lastly, when using an etch primer, I would recommend coating the etch primer with a sandable primer prior to applying your topcoat. The finish quality will be much nicer.
The Following User Says Thank You to PaintChemist For This Post:
Determining paint color from existing old paint Mike Rock Paint Shop 9 10-27-2013 03:37:38 PM
Maytag model 92 paint color do you have to paint green RandyBagley Maytag Engines and Collectibles 2 10-01-2013 10:01:54 AM
Forum Link (Paint Shop) If you are interested in OLD paint - Don't Miss This! Harry Hit & Miss Gas Engine Discussion 0 03-14-2008 09:27:47 AM
Forum Link (Paint Shop) If you are interested in OLD paint - Don't Miss This! Harry Steam Stationary Engines, Traction Engines 0 03-14-2008 09:27:47 AM
paint job chipping, need advice Tom Geier Paint Shop 1 04-14-2007 11:43:26 PM
