John Deere E90 Electric Mower
this thread has 17 replies and has been viewed 2371 times
Old 11-10-2016, 08:02:59 PM
Default John Deere E90 Electric Mower
I got this the 31 of october and just now got around to getting some pics. It works. Just has some chips in the fiber glass and needs good paint and 3 tires. 1 rear is new. I am going to pull the wheels and have the tires took off and clean them and paint them and install new tires.
Mower motors run. I drove it into the shop on the charger as the battery's are bad.
Type S2081 004738M serial
I am looking forward to sharpening the blades and mowing the front yard with it.
I do want to ask, how do you adjust deck height?
Also, was the transmission painted green or left natural aluminum? This 1 has green on it. Could be overspray.
ID:	267736   Click image for larger version
The Following 4 Users Say Thank You to uglyblue66 For This Post:
Old 11-11-2016, 08:02:30 PM
Default Re: John Deere E90 electric mower
I had to go the tire store for other stuff to be fixed and had the tires took off the rims. Rears in good shape. fronts have some rust because of some kind of fix a flat.So in the electrolysis tub they will go.
Old 11-12-2016, 11:54:53 AM
Dick DeBuse Dick DeBuse is offline
I believe those JD electric mowers were re-badged General Electric Elec Traks, later mfd by Wheelhorse.
Old 11-14-2016, 10:41:09 PM
Yukon Yukon is offline
I thought the Elec-Trac was more of a tractor style . That JD is more like ariding mower. just my $.02.
Old 11-20-2016, 12:26:57 PM
I think this is a John Deere product. The rear engine machine that Wheel Horse built after they bought out GE was based on the little Reo rear engine frame machine. I have 1 that was basically new old stock but is in rough shape from poor storage.
Old 11-20-2016, 06:27:11 PM
Fred Van Hook's Avatar
Photo Re: John Deere E90 electric mower
John Deere made 2 models, the 90 and the 96 were both electric.. Here is the one my friend Max owns...
https://www.youtube.com/watch?v=khdtuJv1k9o
International made one like it also..
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
The Following 2 Users Say Thank You to Fred Van Hook For This Post:
Old 11-20-2016, 11:51:13 PM
I have a 96 but it is terrible rough shape.
Old 11-29-2016, 11:36:30 PM
well I have 3 battery's for the machine, and new front tires ordered off ebay.
I have the machine in the shop and will be cleaning it up and maby putting a quick paint job on it. Not trying to make it mint as I will want to run this machine and it would just get dirty and scuffed up anyway.
I am still wondering if the transmission is supposed to have paint on it or not.
Old 12-01-2016, 07:24:40 PM
OrgWayne OrgWayne is offline
Theres a Guy here in western Oregon with one He bought brand new , boy it is really nice , he will talk your head off about it , forgot which one he has A JD for sure
Wayne
Old 01-27-2017, 12:54:11 AM
ronm ronm is offline
We sold quite a few of those when I was at the JD store. People tended to like them until the first set of batteries gave out...then a lot of them got traded in on a 66 or 68 gas model. Batteries were about $150 ea. X3 back then, in the 70's, when 150 bucks was still real money...
No, they were not a rebadged GE or Wheel Horse, they were built in the Horicon works where all the L&G stuff was built.
I don't think the transmission was green from the factory.
Old 03-14-2017, 04:23:04 PM
Well It mowed my front yard today! Did a good job to.
And the batterys were not even fully charged. I finally made a bit a money on some side work and went and bought a new rear tire to match the 1 the machine had on it and I got the wheels finished over the weekend. I was in no hurry to put things together till I walked in the shop yesterday and the work bench I had the batterys sitting on was broke down and about to dump my big heavy arbor press and 6 agm batterys in the floor! So I hustled and fixed that and got the tires mounted on the rear wheels and put things together. I love mowing with this thing. So quite and easy to drive. I have to much other stuff to do right now to paint it so I am just going to run it as is till I get time to fix things right. I would like to replace the key switch as someone put a push pull switch in place of it.
The Following 3 Users Say Thank You to uglyblue66 For This Post:
Old 03-19-2017, 10:25:39 PM
Well I mowed the yard a second time today.
I noticed a sound once in a while that sounded ,well for lack of better word,a dry bearing in 1 of the deck motors. It mows fine. this sound is occasional but I want to investigate.
Does anyone have a break down of what the motor looks like inside or how can I access the top bearing or bushing? I think a drop of oil would probably make a big difference.
I have also found the timer does not work on the charger. It charges but the timer will not turn or turn it off automatically. So at the moment it is on 1 of my golf cart chargers.
So does anyone have a source for a new timer for the charger? I think it is for 12 hours?
Old 06-23-2019, 09:25:22 PM
Question, I replaced the toggle switch and mowed a good bit with the machine,the switch went bad,got hot.
It has messed up the 3rd switch.
I am wondering if some dingbat bypassed a soliniod maby?
BUT I have googled until i am blue in the face and can not find a schematic.I found parts breakdowns and there is 2 solinoids,1 is for the deck and 1 may be for the start winding of the traction motor.But I am thinking of adding a golf cart solinoid in the switch circut to save switches.
Does anyone have a diagram of the wireing for a John Deere 90?
Old 06-25-2019, 08:41:17 PM
Ogrebeast64 Ogrebeast64 is offline
HERE is where is where I found some manuals
The Following User Says Thank You to Ogrebeast64 For This Post:
Old 06-25-2019, 09:11:55 PM
Default Re: John Deere E90 Electric Mower
I searched last night for a while and never did find those manuals.How did you did dat?
Old 06-26-2019, 01:47:50 PM
Thanks for the search.I just bought all 3 of the manuals ,service,owners and parts catalog.So I should have everything I need! 34 bucks worth total. Being these machines were not all that common back then,and few remain,having the tech info for them makes it easier for me to maintain mine and makes it worth a bit more when I get old and grey and can't plug in the charger anymore!
The Following User Says Thank You to uglyblue66 For This Post:
Old 07-01-2019, 01:58:32 AM
I usually start with a web search, but for the older manuals and such, I hit up Ebay first.
Old 07-09-2019, 08:43:43 PM
I had to go by the John deere dealer today to get a cheap plastic part to fix the shifter on a GT262 today and I took my parts manual for the E 90 in there and ask about a key switch that I need for it. Obsolete of course Counter man said he had only saw 1 of the electrics during his carreer.
John Deere #5 or #9 mower help Fifty7ChevyNut Antique Farm Tractors 8 03-15-2015 01:00:47 AM
John Deere E - Electric start Renny Hit & Miss Gas Engine Discussion 1 03-30-2013 05:44:15 PM
John Deere Big #4 mower shoptek Horse Drawn Equipment 9 08-11-2012 08:14:02 PM
Ertl John Deere electric engine Meco3hp Vintage Toy Steam Engines and Motors 2 06-17-2011 07:50:48 AM
