Jacobsen 4 Acre Mower
this thread has 4 replies and has been viewed 1025 times
Old 12-30-2017, 01:50:43 AM
rustyknutt rustyknutt is offline
Default Jacobsen 4 Acre Mower
I just aquirred 2 Jacobsen 4 acre mowers and a parts mower without handles and a few other things.
Im trying to ID the years on them. I have a steel wheeled mower which i Identified the year, and a parts mower i have dont the same with. They both had tags with numbers.
NUMBER THREE, is a 4 acre with rubber tires and a caster wheel included in the rear. LOOKS LIKE...it had a (Sickle Bar) attatchment. I cannot seem to find a tag with serial number on it anywhere. Can anyone help me on this. Usually they are on the front under the motor. Pics included.
1. 3558 is a 1926 4 acre with steel wheels
2 2816 is a 1924 partial 4 acre with steel wheels
3. unknown number or year 4 acre with rubber tires and caster wheel.
4. same
ID:	299286   Click image for larger version
ID:	299287   Click image for larger version
ID:	299288   Click image for larger version
Old 12-30-2017, 11:40:15 AM
Junkologist's Avatar
Default Re: Jacobsen 4 Acre Mower
Nice finds! I especially like #1. Looks like a super nice original machine.
Mike
SmokStak member #146
Old 12-30-2017, 03:18:58 PM
If you look carefully at the edge of the engine base, either in the front or rear, Jacobsen often stamped in the numbers. Without the mower plate, it is difficult to date. Jacobsen did not keep engine numbers, only mower or implement #s. With the bolt on muffler, it will be a later version. The 4 acres with the castor wheel came with a sulky! Easier turning. I have not heard of a 4 acre with a sickle bar. Might be a different model. Nice finds! mower.
Old 12-30-2017, 07:00:37 PM
Got into a couple of those ONLINE AUCTIONS this fall and winter. got really lucky.
Old 08-11-2019, 12:19:04 AM
Blacksmith Jim Blacksmith Jim is offline
On eBay now Jacobsen 4 Acre engine decal at jimenginedecals
eBay item number: 153597548308
Jacobsen 4 acre mower identification and help poserkidsrus Garden Tractors and Mowers 0 05-01-2015 10:02:48 PM
Jacobsen 4 acre mower Jeff Conner Garden Tractors and Mowers 7 03-24-2013 06:25:57 PM
Jacobsen 4 Acre Mower Tilinghast Hit & Miss Gas Engine Discussion 13 04-19-2010 11:03:26 AM
Jacobsen 4 Acre Mower Mag. Help James Wallace Garden Tractors and Mowers 4 02-19-2009 03:44:52 PM
Jacobsen Four Acre mower engine Manuel Azevedo Small Air Cooled Gasoline Engines 7 06-12-2008 05:50:12 PM
