Paint Shop
Painting Hightemp Silicone sealer
this thread has 3 replies and has been viewed 885 times
Old 02-20-2018, 07:29:42 PM
Tom Jamboretz's Avatar
Tom Jamboretz Tom Jamboretz is offline
Default Painting Hightemp Silicone sealer
Just finished making a model Robinson Hot Air engine. In the process some Hi temp silicone is exposed. Is there some treatment I need to do before spraying rattle can Rustoleum? TJ
Old 02-20-2018, 08:34:24 PM
DustyBar DustyBar is offline
Default Re: Painting Hightemp Silicone sealer
Silicone is one of the most difficult things to paint over. I don't think there is any treatment you can do to change that. A body shop I worked in banned all silicone products since a wiff of it in the shop caused instant fish eyes in painting in progress in the paint booths.
The Following User Says Thank You to DustyBar For This Post:
Old 02-21-2018, 12:47:38 PM
Paint will not stick to it. Besides the silicone, it gives off an acid vapor over time, that will remove the paint anyway. read the instructions on the product label for removal, and take as much off as possible. maybe you can use another product that would be paintable, like a refractory cement?
Old 02-21-2018, 04:11:35 PM
OTTO-Sawyer's Avatar
Personally, looking at your model, I'd just take a razor blade and trim it off flush with the castings, or just a little proud of being flush (to get rid of the bigger blobs) so you can paint it and then carefully finish trimming it flush after painting.
Shouldn't look any worse than any other gasket material that would be visible if it were painted and then assembled.
Using silicone on handhole gaskets ddrawz Steam Stationary Engines, Traction Engines 35 01-18-2017 11:42:36 AM
Black Permatex silicone gasket maker ronny p 148 Farm Antiques and Collectibles 5 03-15-2014 06:49:09 PM
Silicone gas line Dwayne Oxford Small Air Cooled Gasoline Engines 6 11-27-2013 05:52:13 PM
gas tank sealer gone bad Kyle K Hit & Miss Gas Engine Discussion 26 01-07-2013 08:41:22 PM
Boat painting, sealer and color 12wire Paint Shop 8 01-28-2009 01:47:17 AM
