Steam Engines
Is this a Steam Engine Serial Number Plate or Badge?
this thread has 4 replies and has been viewed 1068 times
Old 05-08-2018, 05:28:39 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
Default Is this a Steam Engine Serial Number Plate or Badge?
Just wondering if anyone knows if this is a steam engine serial number plate and if they can identify the make by the style of tag? Thanks
ID:	310029   Click image for larger version
The Following User Says Thank You to Joel Mosley For This Post:
Old 05-08-2018, 05:31:27 PM
David's Avatar
David David is online now
Default Re: Is this a steam engine serial number plate or badge?
I would guess it to be from an early Frick engine. Others may guess it to be from another maker.
David
The Following User Says Thank You to David For This Post:
Old 05-08-2018, 08:28:50 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Joel I'm going to disagree with David. That looks like an early Case tag from a center crank. This is a picture of one I've seen personally. Maybe Glenn G. or Colin can Comment more on it.
Tim Colwell
JD & IHC corn sheller and engine collector.
The Following User Says Thank You to Tim Colwell For This Post:
Old 05-08-2018, 08:30:21 PM
Tag comes from the case mentioned in this thread. https://www.smokstak.com/forum/showthread.php?t=30777
serial number is in the right range too..
Tim Colwell
Old 05-08-2018, 08:38:54 PM
halcon halcon is offline
That engine number would have been used in 1886 so it is an oldy.
The Following User Says Thank You to halcon For This Post:
Aultman Taylor Serial Number Plate Joel Mosley Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 04-18-2016 03:30:54 PM
Serial number plate for a 35 John Deere B Johnny D 1837 Antique Farm Tractors 7 03-20-2014 09:15:11 AM
Case HP/ serial number badge chrsbrbnk Steam Stationary Engines, Traction Engines 6 04-05-2013 08:19:29 PM
Mc Deering 10-20 serial number, data plate David Wilson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 10-26-2009 03:44:04 AM
Galloway Serial Number Plate Bob Johnson Antique Engine Archives 9 11-22-2004 07:44:23 PM
