1935 Twin City FTA
this thread has 35 replies and has been viewed 3718 times
Old 05-27-2018, 08:31:57 AM
Russ Hamm's Avatar
Default 1935 Twin City FTA
Just picked this up yesterday, runs pretty good needs some tweaking here and there but I already have the fenders more straight than in the pics. Has a TC top radiator tank but it is a 1935 21-32/ FTA for sure. Seems to be a solid ol tractor, may have to see how this one pulls a plow this summer.
ID:	311288   Click image for larger version
The Following 14 Users Say Thank You to Russ Hamm For This Post:
Old 05-27-2018, 11:37:41 AM
J Ware J Ware is offline
Default Re: 1935 Twin City FTA
Not bad looking old tractor Russ, my 35' KTA has TC on the radiator tank. We both have the same 3 T C models now. They grow on you, don't they. My FT idles so nice just wish I had a set of lugs so I could plow with it. Would a set off a 22-36 fit, the bolt spacing the same. Jim
The Following 2 Users Say Thank You to J Ware For This Post:
Old 05-27-2018, 12:17:13 PM
gleaner gleaner is offline
The radiator top is correct for a 1935 FTA.
The Following 2 Users Say Thank You to gleaner For This Post:
Old 05-27-2018, 10:00:33 PM
Jeff Blaney Jeff Blaney is offline
Russ, I am curious about the information displayed on your tractors serial tag. Is the tractor tagged as an 21-32 (FT) or an FTA as they are two distinct models. The FTA was introduced in 1935 so I can see how both new and old stock parts would have wound up on the same tractor.
The Following 2 Users Say Thank You to Jeff Blaney For This Post:
Old 05-29-2018, 08:44:58 AM
Russ Hamm's Avatar
I can get a picture of the tag, from what I remember the lower left says 21-32 and the lower right says FTA, I suppose HP and Model respectively.
I have a problem maybe someone could help out with.
Got the tractor home and had noted that the oil was a little milky. Decided to change it, sure enough there was a little water in the pan, not much but I think most of what was there mixed in the oil pretty good. Went to 30 weight oil, opened the filter housing and found no filter. As I was going to run it this weekend I put it back together. I should note at this time, when I pulled the filter housing drain plug there was a rod sticking down a bit, seemed spring loaded.
I started the tractor and the filter housing leaked, had to stop and change the o-ring. Started it up and in a moment the exhaust started to smoke out the shop, it was bad. Now black oil is leaking out the exhaust gaskets and running down the side of the block.
Before I changed oil, it didn't smoke an ounce. Does anyone have a filter housing cutaway view for this or a KTA? I'm pretty sure I did something wrong, sure the valve guides probably need attention but I pulled the valve covers, started it and im pretty sure its over-oiling, oil was shooting out the rockers pretty high. The guage is old, but it says 30psi , I thought originally it was high anyway, but...……….
The second time I changed the o-ring in the filter housing that rod dropped down out the hole a little further, by the way. No steel parts in the drain bucket that I could find.
Help, what did I do?
Also, had this old muffler laying around for years, good ol thick steel and it fits.
Old 05-29-2018, 06:15:15 PM
I am no expert when it comes to the pressurized lubrication systems on these tractors but I don't believe there should be anything behind the filter housing drain plug. There is however the relief valve located right near it, which is spring loaded. Pressure should be around 25psi.
Going back to your serial number tag, that is interesting about the tractor having both the 21-32 and FTA dedignation. It was my understanding that the 21-32 designation was dropped once the tractor was re-rated and renamed. But, just about anything was possible during these crossover years.
The Following User Says Thank You to Jeff Blaney For This Post:
Old 05-29-2018, 10:11:25 PM
Russ, here is a cut away photo of the oil filter assy. and also a picture of the filter element cleaning instructions. I hope this helps. I use the same oil filter as the MM G. Jim
The Following User Says Thank You to J Ware For This Post:
Old 05-30-2018, 08:26:18 AM
Russ Hamm's Avatar
Jeff, here are the plates, I haven't looked at enough of them to know much. I wonder though if the engine serial numbers ever match or get close.
Did these ever come with rubber tire gearing or special speeds at all? Seems like first gear is kinda fast.
ID:	311450   Click image for larger version
Old 05-30-2018, 09:06:48 AM
Molinegb Molinegb is offline
My 12-20 serial numbers are one number apart from motor to chassis.
The Following User Says Thank You to Molinegb For This Post:
Old 05-30-2018, 09:18:19 AM
Russ Hamm's Avatar
Photobucket finally allowed me to dredge up this old picture I had of one that a friend had me get running for him years ago. It was stuck but we got it loose very easily and it ran really well. He sold it soon after at an auction, don't know where it went. Its been long enough that I couldn't remember much about it except it was very tall on rubber tires.
Old 05-30-2018, 10:36:52 AM
I have never heard of a road gear in these tractors, maybe that was an option on the Industrial model? The FT had two forward speeds where the FTA had 3.
Old 05-30-2018, 12:26:03 PM
21-32 or FT had 3 speed as well as FTA starting in 1929. Early 21-32 1926-29 had 2 speed. FT had 4 1/2 bore (381) where FTA had 4 5/8 bore (403)
The Following 3 Users Say Thank You to Molinegb For This Post:
Old 05-30-2018, 01:22:59 PM
Here are the pics
ID:	311464   Click image for larger version
Old 05-30-2018, 07:12:18 PM
I have a 1938 with factory 12mph road gear. When I was a kid and we ran several 21-32's it was great when moving fields but not so great in the field as you lost a field gear and it has 2nd gear too fast for gumbo plowing so you found yourself in 1st a lot creeping along but the other 21-32's would pass you as they never went lower than 2nd and in many times could plow in 3rd.
I have thought a lot about the days when we ran them. Most in this area were converted to LP. My 1938 is still on LP
The Following 3 Users Say Thank You to gleaner For This Post:
Old 05-31-2018, 02:43:20 PM
Russ Hamm's Avatar
Thanks to Jim's drawing I did some testing last night, ordered a repair manual but won't be here right away. I backed the pressure down from 30 psi to 25 and had less oil running down the block but still smoke out the exhaust. I'm betting on valve guides but by that time my theory has always been to do the rings also. Its probably going to the show as a stationary exhibit this year unfortunately.
Still, I got a darn good deal on this tractor and i'm not disappointed a bit. Afterall, how many times have you bought a good running tractor and wondered about the internals? This tractor has darn good compression and seems to get even better every time I start it, if I take one apart and discover I didn't need to do rings I never feel like I wasted any time. Sort of peace of mind mechanics you could say. And when I find something that needs attention i'm actually relieved I found it
I am thinking about a further test on the valve guides, I may just re-route the oil lines for the rockers back into the lifter valley and see what happens. For the show, we will change oil to 40w non detergent and try a good accurate guage on the pressure, see what happens then. Our show is the first of august and its plenty warm enough then for heavy oil. Plus, if I find the guides are for sure the problem, I may try to install some temporary valve stem seals.
Old 05-31-2018, 03:30:47 PM
Slobbering out exhaust means unburnt fuel. I would say stuck or broken rings. Guides would give you blowby. Guide weren't really an issue with MM's. Let it run for a while to see if it quits slobbering.
Old 06-01-2018, 01:02:56 AM
Jim Anderson's Avatar
Jim Anderson Jim Anderson is offline
Hi Russ
Here is a list of the optional gears listed for the FTA.
The Following 3 Users Say Thank You to Jim Anderson For This Post:
Old 06-01-2018, 09:05:59 AM
Russ Hamm's Avatar
Yeah, its time to take it apart and look. I tested it some more last night, the smoke is getting a little bit less but at higher rpm the oil is coming out more. Pulled the plugs and the top of the pistons are pretty wet, looks like number four cylinder is the worst with number one second and the center two are damp. I never had much luck freeing up stuck rings by running any length of time, seems like.
Anybody know the width of the rings on these and the number, etc?
---------- Post added at 08:05:59 AM ---------- Previous post was at 07:54:32 AM ----------
Originally Posted by Jim Anderson View Post
Hi Russ
Attachment 311566
Makes me wonder now, thanks. I drove it around a little bit and tried every gear, it was getting dark and at one time I wondered if I was in first gear, tried it again and just thought there wasn't a whole lot of difference between speeds or that they were all faster than I was used to on my Internationals.
Not sure just yet, anyway, didn't run it terribly long as I haven't checked lube levels on the rear and had some gear noise. I need to replace the center clutch plate or drill new holes as its ringing pretty badly, been drilled once already.
Old 06-01-2018, 12:55:01 PM
Russ this is a FTA Twin City. Gear noise and the ringing of the center plate is normal! When you are plowing that ringing goes away. I can't guess the hundreds of hours I have set on the tool box riding on the 21-32 as a child and the hundreds of hours running one pulling a 3-16 Moline plow. Those sounds you are wanting to get rid of are normal and music to me.
You are making me want to get me a rusty old beater just to run in the field again.
The Following User Says Thank You to gleaner For This Post:
Old 06-01-2018, 03:21:50 PM
3-FE123 and 1-FE 433 . Just a standard 1/4 ring x 4 5/8 unless someone has been in there. Have a set of HC blocks,heads and pistons that came off a 21-32.
---------- Post added at 02:21:50 PM ---------- Previous post was at 02:02:28 PM ----------
You can take blocks off and reinstall without removing bottom end. Tricky but can be done.
The Following 2 Users Say Thank You to Molinegb For This Post:
Twin City Big Twin Cam up for Sale Mark Schneider Live Auctions of Engines, Tractors and Old Iron 29 02-28-2019 12:04:46 AM
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
New Member of the Twin City Twin Cam Fraternity J Ware Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 22 09-06-2017 12:25:53 PM
1935 Twin City 21-32 On Steel 1206SWMO Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 04-01-2015 09:06:33 PM
1935 Twin City FTA 00p225 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-12-2014 09:30:29 PM
