Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
Link - Belt Speeder LS 60 S/N 8241
this thread has 7 replies and has been viewed 878 times
Old 12-12-2018, 02:58:56 PM
J and M Boyajian J and M Boyajian is offline
Default Link - Belt Speeder LS 60 S/N 8241
We are getting ready to move a Link - Belt crane and would like to know
what the wt. is? It has a 40 ft. boom, track pads are 16 inches wide, the cab is 10 ft. tall, width 8 ft., flat head engine, axel to axel 8 ft. 7 inches. What year?
Thanks for any help.
John and Mike
Old 12-12-2018, 08:10:06 PM
Default Re: Link - Belt Speeder LS 60 S/N 8241
Not familiar with Linkbelt models, but dimensions are similar to Bucyrus Erie models such as 19-B. Such machines weigh in around 19 or 20 tons, but may carry extra external counterweight as well.
Sure someone here knows Linkbelts, so perhaps if you post a photo you can get an ID and an accurate weight. Good luck with the project.
Combustor.
The Following User Says Thank You to Combustor For This Post:
Old 12-13-2018, 12:25:49 AM
tdmidget tdmidget is offline
Used to run an LS 78, 98, and 108. The LS78 was 30 ton capacity,
I found a load chart for a LS58. With 30 foot boom and ABC counterweights it would lift 20,800 lbs. It has to weigh a bit more than twice the capacity so I'll guess around 50,000. Boom and counterweight slabs on 1 load and the balance on another and you should have no problems.
The Following User Says Thank You to tdmidget For This Post:
Old 12-13-2018, 06:46:04 PM
BHoward BHoward is offline
I had a Thew Lorain about that size and it had a Buda flat head 6 engine. I think it was 1940. Don,t know what it waighted.
The Following User Says Thank You to BHoward For This Post:
Old 04-01-2019, 09:09:46 PM
IronworkerFXR IronworkerFXR is offline
I have an LS 50 ,book weight is 25,500 # with the cable shovel
its a 1947
like to see pics of yours
The Following User Says Thank You to IronworkerFXR For This Post:
Old 04-01-2019, 10:26:16 PM
Heins Heins is offline
My book doesn't list a LS 60.
It lists a LS58 29,000#
LS 68 38,000#
I don't think my book goes back far enough, It doesn't show any with a gas engine.
Old 04-04-2019, 11:57:11 PM
Thanks for all the information. We have not moved it yet but when we
get it home we will take some pictures. We do not know how to post pictures
but we can email you some pictures. We only have to move it 8 miles.
We found the drive chains for it. They were taken off when they moved it.
We grow grapes for raisins and have been busy with the farming work.
Thanks,
John and Mike
Old 07-01-2019, 08:17:01 PM
ScooterBob ScooterBob is offline
This thread tells you how to upload pictures to this forum that ae on our computer...
https://www.smokstak.com/forum/showthread.php?t=40589
The Following User Says Thank You to ScooterBob For This Post:
Old Link belt shovel on CL Firewoodguy Live Auctions of Engines, Tractors and Old Iron 0 07-26-2013 04:03:51 PM
Fairmont speeder car Tom Sampson YouTube Old Iron Videos 0 06-03-2012 08:38:41 PM
saw this speeder on another site.. Jim Sherman Hit & Miss Gas Engine Discussion 0 01-25-2012 06:52:04 PM
Link Belt Excavator at Portland? dannyinky Hit & Miss Gas Engine Discussion 3 09-05-2010 07:31:18 PM
