Detroit Model G Oiler - Compression Fittings
this thread has 7 replies and has been viewed 976 times
Old 02-10-2019, 03:04:58 PM
Jeff Blaney Jeff Blaney is offline
Default Detroit Model G Oiler - Compression Fittings
I need some input with regards to a Detroit Model G, five port lubricator I am rebuilding. I have run into some issues with the brass fittings and ferrules used and their compatibility with todays modern fittings.
I posted the question originally on the Oiler/Lubricator Board, but figured you good people might want to chime in.
http://https://www.smokstak.com/forum/showthread.php?p=1552518#post1552518
The Following User Says Thank You to Jeff Blaney For This Post:
Old 02-10-2019, 07:30:33 PM
Ed Noli's Avatar
Ed Noli Ed Noli is online now
Default Re: Detroit Model G Oiler - Compression Fittings
Something like this may work. McMaster Carr lists others.
https://www.mcmaster.com/5272k604
The Following 2 Users Say Thank You to Ed Noli For This Post:
Old 02-11-2019, 08:39:34 AM
Bubbles Bubbles is offline
The one listed by Ed is a copy of a Swagelok 2pc ferrule.
I would make your own nuts and possibly your own ferrules if the Swagelok style ferrules won't work.
The Following User Says Thank You to Bubbles For This Post:
Old 02-22-2019, 02:04:40 PM
Fabricating nuts from brass hex stock seems to be a straightforward solution, however I am finding it difficult to find the right size tap. These threads are 7/16-22. I have contacted our local tooling supplier, one in the U.S. that used to stock this size, as well as McMaster-Carr. Not one supplier seems to carry this size anymore. There is a 7/16-20 and a 24, but not a 22. A custom tap can be made, but they are $150 per piece....
Has anyone had any luck fabricating their own custom thread taps?
Old 02-22-2019, 03:59:59 PM
I would cut them on the lathe with a single point tool to save buying a special tap $$$$$.
The Following 2 Users Say Thank You to Bubbles For This Post:
Old 03-21-2019, 07:12:57 PM
After speaking with an early automobile collector who experienced the same issue I have, I decided to fabricate new banjo’s equipped with the modern 7/16-24 thread and ferrule profile. This was an inexpensive solution, looks damn near original and best of all, it works!
The new banjo’s have a slightly larger outer diameter than the originals so that the 1/8 NPT fittings have sufficient thread engagement. Our baby 1/4” boring bar came in handy fitting the new banjos to the original bolts. Once the fittings were threaded in and the excess removed, I bored the banjo out to its final diameter.
1. 3/4” Brass Round Stock and Original Banjo Fitting.
2. Cut to length and boring out round stock.
3. Drilling hole for 1/8 NPT fitting.
4. Plunging through excess thread.
ID:	331106   Click image for larger version
ID:	331107   Click image for larger version
ID:	331108   Click image for larger version
The Following 7 Users Say Thank You to Jeff Blaney For This Post:
Old 03-21-2019, 07:18:24 PM
Here’s some pictures of the finished banjo fittings and how they appear on the lubricator, pumping away. Due to the larger O.D. of the banjo, I had to machine a small flat on the backside so the brass sight glass hood would fit properly.
I had considered other options to solve the problem of these original obsolete fittings, but this seemed the most practical.
ID:	331110   Click image for larger version
The Following 10 Users Say Thank You to Jeff Blaney For This Post:
Old 03-22-2019, 11:19:01 PM
Looks like an excellent fix to repair an old oiler!
Detroit Model G - Brass Compression Fittings Jeff Blaney Oilers, Lubricators and Grease Cups 1 02-10-2019 02:56:35 PM
Old vs New tube compression fittings JoeCB Antique Marine Engines and Outboard Motors 3 04-11-2014 04:15:53 PM
Vintage Compression Fittings - photos? Robt. The Junque Drawer 1 02-26-2013 02:13:54 PM
Information on Compression Fittings Vernon Rublee Hit & Miss Gas Engine Discussion 5 03-27-2011 01:28:18 PM
What year did compression fittings come out? bills Antique Engine Archives 0 05-31-2002 04:59:24 PM
