John Deere LUC, Number on spark plug?
this thread has 3 replies and has been viewed 601 times
Old 04-17-2019, 10:27:26 PM
bmklawt bmklawt is offline
Default John Deere LUC, Number on spark plug?
Bought an old LUC power unit without a mag, found a NOS mag and have some new spark plug wires but which is the number one spark plug on the engine and on the mag?
Your help is greatly appreciated,
Old 04-17-2019, 11:06:16 PM
ulgydog56's Avatar
Default Re: John Deere LUC, Number on spark plug?
have a luc, same as la motor, the bottom wire from mag goes to the rear cylinder top to front, I,ll check it tomorrow to make sure.....
Old 04-18-2019, 10:53:06 PM
ulgydog56's Avatar
o.k.....I got it backwards...lower outer port on mag goes to front cylinder and inner higher port goes to rear cylinder......the timing cover is rear of mag and has a timing mark, message me if you need more infro on engine I have specs...
Old 08-03-2019, 06:23:16 PM
Okay, I got this figured out, the outside lug on the mag goes to the front number one cylinder, the inside lug on the mag goes to the rear number 2 cylinder.
Bruce
John Deere 1 1/2 HP (Spark Plug) Model E Value Dale Russell Hit & Miss Gas Engine Discussion 7 01-12-2018 11:17:37 AM
John Deere Spark Plug Wires Looking for A mericle Antique Farm Tractors 4 01-11-2014 04:57:51 PM
John Deere E spark plug 1 1/2 billmatteson104 Hit & Miss Gas Engine Discussion 20 08-08-2010 09:50:23 PM
John Deere E - spark plug or not? C Martin Antique Engine Archives 3 04-27-2004 09:21:45 PM
1 1/2 john deere spark plug E.W. Antique Engine Archives 1 07-08-2002 04:14:35 PM
