AT 4 Impulse Coupling
this thread has 1 replies and has been viewed 397 times
Old 04-24-2019, 01:05:00 AM
P. Kelly P. Kelly is offline
Default AT 4 Impulse Coupling
Anyone have a diagram of a Bosch AT4 IC magneto impulse coupling?
Old 04-24-2019, 11:35:22 AM
Russ Hamm's Avatar
Default Re: AT 4 Impulse Coupling.
Google 'magneto data sheets' and you may find something at old engines.com like this. Don't know if you will find exactly what you need there but it is a great source.
The Following 3 Users Say Thank You to Russ Hamm For This Post:
Wico magneto... impulse coupling Winchester Smokstak Down Under 24 01-12-2016 05:39:50 PM
FM 40 B Magneto Impulse Coupling Kyle K Hit & Miss Gas Engine Discussion 1 09-01-2015 12:28:31 AM
farmall H 4 magneto impulse coupling mshm99 Magnetos, Ignition Coils and Spark Plugs 1 08-29-2015 12:32:20 PM
Could the Impulse Coupling be Mounted Wrong? todengine Magnetos, Ignition Coils and Spark Plugs 2 12-03-2013 09:32:38 PM
Impulse coupling Alan James Hit & Miss Gas Engine Discussion 11 01-22-2008 03:20:34 AM
