1929 John Deere D, emergency brake
this thread has 7 replies and has been viewed 610 times
Old 04-26-2019, 09:03:53 AM
bmklawt bmklawt is offline
Default 1929 John Deere D, emergency brake
Should the emergency brake on my 1929 John Deere D hold the tractor and keep it from moving if I try and drive it.
I sometimes find I've been driving with the emergency brake on because I can't feel any difference in the drivability with it on or off.
On a level concrete surface, I can push my tractor around by hand but not with the emergency brake on, this is the only indication I have that it is working at all.
Thanks,
Bruce
Old 04-26-2019, 12:13:07 PM
Russ Hamm's Avatar
Default Re: 1929 John Deere D, emergency brake
Its sort of just a parking brake and since it runs in oil I think the ol D will overcome it easily in gear. I think they should sort of break over to brake, mine I have to hold and I don't have the remote linkage for it that was an option.
Old 04-26-2019, 12:18:50 PM
Dave16405 Dave16405 is offline
My '29 D will also move with the brake on but it is noticeable. It will hold the tractor in place when belted up to something.
The Following User Says Thank You to Dave16405 For This Post:
Old 04-26-2019, 01:07:09 PM
I had a '27 D and and a '43 D.
The parking brakes on them weren't worth a rip......
The Following 3 Users Say Thank You to Craig A For This Post:
Old 04-26-2019, 06:24:51 PM
CBarth66 CBarth66 is offline
My '27 D brake isn't the best at holding much either. But when completely engaged and it is broke over center, it does hold the tractor when I have it belted up to something. I think that's what they were mainly used for and not braking to slow when moving.
The Following User Says Thank You to CBarth66 For This Post:
Old 04-26-2019, 10:03:59 PM
halcon halcon is offline
If you can put that brake on when belting up you must be 9 feet tall.
Old 04-26-2019, 11:08:51 PM
Duey C Duey C is offline
Other marque's parking brakes stink also after 90 years.
I don't feel alone anymore. Want to relign it on one.
Old 04-28-2019, 12:12:02 AM
You havn't used the on a 15-30 McCormick Deering, they work.
The Following 2 Users Say Thank You to halcon For This Post:
1929 Deere D, differential gears move when applying emergency brake bmklawt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 09-04-2017 08:57:17 PM
John Deere B brake drum Dave Edmonds Antique Farm Tractors 5 06-05-2017 10:50:20 PM
John Deere D Brake dzgreenacres Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 12-23-2015 05:36:24 PM
John Deere B Brake disassembly coolkp Antique Farm Tractors 6 07-23-2015 12:48:11 PM
John Deere Model D Brake Mike S Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 02-25-2015 02:57:54 PM
