Briggs and Stratton Intermittent Problem
this thread has 23 replies and has been viewed 954 times
Old 06-16-2019, 12:43:38 PM
EddyC EddyC is offline
Default Re: Briggs and Stratton Intermittent Problem
Thanks for the replies. Is the restriction something I could just look into the tank and see or is there another method? And if it were a restriction, would the fuel filter be empty when the stall out happens?
Old 06-16-2019, 04:25:33 PM
Elevated Elevated is offline
Next time it quits, maybe try carefully separating the fuel line from the fuel filter, and using your mouth, blow gently back into the tank. Remove the gas cap first. If itís plugged, it may offer resistance. If you can see the fuel outlet in the tank, shine a flashlight at it and blow gently and see what comes out.
Old 06-17-2019, 10:46:02 PM
Is that something that would resolve with it sitting for a while as it always starts back up eventually?
Old 06-18-2019, 12:58:30 AM
Ogrebeast64 Ogrebeast64 is offline
It'll let you know is the screen in the tank is clogged, restricting fuel flow.
8 HP Briggs & Stratton Start Problem Paso One Small Air Cooled Gasoline Engines 11 04-17-2011 08:10:58 PM
Briggs & Stratton ZZ problem. Military Dave Military MEP and Aircraft Gen-Sets 11 03-13-2011 10:48:52 PM
Briggs and Stratton 3.5Hp Problem petesoldsaw Garden Tractors and Mowers 8 05-11-2010 02:49:34 PM
12.0 DJC Intermittent Output Problem Steve Dawkins Onan Generators 2 04-24-2005 12:54:32 AM
Briggs & Stratton Problem John Edwards Generators & Electric Motors General Discussion 3 03-15-2003 08:31:30 PM
