Sears 10XL Drive Belt Problem
this thread has 9 replies and has been viewed 410 times
Old 06-22-2019, 12:28:14 PM
Jim18655 Jim18655 is offline
Default Sears 10XL Drive Belt Problem
Sears 10XL garden tractor, 2 speed rear. Worked well for the 25 years I've owned it. Last year the drive belt broke and I replaced it with the correct size belt (B70) and it never worked right since. I followed the adjustments listed in the manual but couldn't get the clutch to release the belt. It continues to turn and grind the gears or keeps driving. I changed to a B71 and it worked for a while and now acts the same way. The belt gets hot and won't release. Can't shift or stop.
So, wrong belt material, improper adjustment, or worn drive pulley allowing the belt to seat too deep?
Thanks.
Old 06-22-2019, 02:01:08 PM
Ken Karrow Ken Karrow is offline
Default Re: Sears 10xl drive belt problem
Don't know if it is your problem but I have found fabric covered belts do much better in clutch service. With the others the rubber surface gets sticky and do not engage smoothly and do not release right. Hope others can help with your exact problem.
Old 06-22-2019, 02:39:13 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
We had one that worked fine till someone changed the belt. They used the right belt but it kept getting tore up and getting between the pulley and gear case. I finally realized that the belt guide guard was removed, it holds the belt where it needs to be, in relation to the pulley, when the clutch pedal releases the tension. Without it the belt slack isn't at the pulley where it needs to be. I made a new one an installed it, no more trouble.
Old 06-22-2019, 03:34:20 PM
All the guards are in place. I loosened the belt and it's a little better but that's only a patch. I'd like to find out why it won't work with a new belt and adjusted per the book.
Old 06-22-2019, 04:14:38 PM
you need a power transmission delt,not a fractional hp belt.
Old 06-22-2019, 04:16:03 PM
Power Power is offline
As Ken said, you need a fabric covered belt for clutch service. Newer design belts are intentionally designed to minimize slippage, and will not perform properly in clutch service. I have run into same issue.
Old 06-23-2019, 10:50:38 AM
Anyone suggest a part number and manufacturer?
Old 06-23-2019, 11:30:37 AM
Elevated Elevated is offline
Napa, 5L730W geeen belt.
Old 06-23-2019, 11:23:38 PM
CharlieB CharlieB is offline
Another vote for using a fully wrapped belt. Belts with raw rubber edges
tend to grab when used as clutches. Kevlar wrapped B-section belts are available from many sites listed on Google.
Also, a V-belt has a natural tendency to spring into a circular shape. That's a problem when the belt is used in a clutching application because when the belt tension is released to disengage the clutch, the belt still remains in contact with both pulleys. Restraining pins or guides are needed to hold the slackened belt in a location just barely outside its path when tensioned. Maybe these guides have been compromised on your tractor?
Old 06-24-2019, 11:04:52 PM
I think the guides are OK. I bought a cheap belt because I don't use the tractor except for plowing snow and hauling around some yard work. I just thought a short belt life would be the only problem with the cheaper belt.
Better belt is coming.
Thanks for the help.
Sawmill drive belt KevinJ Steam Stationary Engines, Traction Engines 21 08-16-2013 04:06:20 PM
V belt drive-belt tensioner schems robert d Garden Tractors and Mowers 2 02-15-2012 10:33:45 AM
Drive Belt Question wegotallama Hit & Miss Gas Engine Discussion 18 05-22-2009 06:14:12 AM
Speedex Drive Belt Rich Lehr Garden Tractors and Mowers 1 01-24-2007 07:55:44 PM
Canvas Drive Belt Tom G Antique Engine Archives 2 04-07-2002 10:27:43 PM
