Farmall 560 Glow Plug Gauge
this thread has 2 replies and has been viewed 332 times
Old 07-07-2019, 01:06:52 AM
Ralph Erb Ralph Erb is offline
Default Farmall 560 Glow Plug Gauge
I just bought a Farmall 560 (new rear tires, near new front tires, runs great, great paint and really straight sheet metal for $2500. The Glow Plug Gauge doesn't seem to work. Exactly what does it do? Is it a temperature sensing gauge; measure resistance of the glow plugs? In looking at pictures, I see some that have calibrations as if someone replaced it with some other guage. Mine just has moon type dots. Any help?
Old 07-07-2019, 08:18:18 AM
Default Re: Farmall 560 Glow Plug Gauge
It's just an amp meter basically. Mine just goes full scale to let you know you got some plugs pulling some amps.
These old glow plugs are SLOW. 30-60 seconds in warm weather and 2 minutes in cold. You just time it yourself and guess when they are hot enough oh BTW the switch is stiff enough to give you a hand cramp in a minute or so.
The Following User Says Thank You to pegasuspinto For This Post:
Old 07-07-2019, 08:54:09 AM
Kelly Tytlandsvik Kelly Tytlandsvik is offline
And if you want to test your glow plugs just remove the wires from the glow plugs and use a jumper wire connected to the battery and flick it on the glow plug terminal. If it sparks its good....no spark no good! One or two glow plugs out makes a big difference in starting!
Kelly T
The Following User Says Thank You to Kelly Tytlandsvik For This Post:
Well I made a 7/16-20 glow plug! brianh Onan Generators 2 01-30-2019 04:48:41 PM
Ruston Glow Plug JD840 Vintage Diesel and Oil Stationary Engines 5 08-03-2018 08:02:27 AM
IHC Model 444 Glow Plug G Willikers Antique Farm Tractors 5 08-25-2017 06:42:40 PM
Mep-002 Glow plug PBZ Military MEP and Aircraft Gen-Sets 12 05-30-2015 12:20:14 PM
MEP003 glow plug billriches Military MEP and Aircraft Gen-Sets 2 01-30-2014 03:27:07 AM
