Ferguson 23C engine
this thread has 3 replies and has been viewed 356 times
Old 07-08-2019, 11:07:37 AM
Dreamweaver Dreamweaver is offline
Default Ferguson 23C engine
Hi from Portugal,
Newbie on here,so bear with me.
I bought this 1957 Ferguson with a view to restore it in my retirement here from the U.K.
I have removed the cylinder head and most of the waterways are clogged up with sediment and general crud that needs removing.
Is there any useful info that anyone can suggest to remove the crud,leaving the head to soak in some recommended solution perhaps? Suggestions grateful received.
David
Old 07-08-2019, 02:03:46 PM
Heins Heins is offline
Default Re: Ferguson 23C engine
I worked on an 8N Ford tractor that the engine looked like yours. I stripped it down and took it to a machine shop and had them "hot tank" it to clean it up.
Old 07-09-2019, 10:20:30 AM
RoFoCo RoFoCo is offline
Hi
I've previously used alloy wheel cleaner, which is acidic, and then pressure washed out the water jacket as best I could. You may need to be careful though if the engine is fitted with wet liners (?), as this could destroy the seals.
In warmer climates, owners often don't use antifreeze, which promotes bimetallic corrosion, which can clog up the radiator and water jacket. I once owned a BMW which had spent it's life in South Africa, and with no use of antifreeze, an iron block, aluminium head and copper radiator, it was in a terrible state!
Best wishes, Roger
Old 07-09-2019, 02:30:26 PM
Welcome to STAK David.......
Ferguson and Massey Ferguson Tractors casertractor Antique Farm Tractors 5 05-16-2019 06:57:46 PM
Ferguson TE20 History and Archive - The Ferguson System casertractor Antique Farm Tractors 0 10-31-2018 10:28:56 PM
Minneapolis Moline Jet Star 2 - MASSEY FERGUSON: Super 90, Ferguson diesel &much more gambler Hit & Miss Gas Engine Discussion 0 08-23-2013 08:49:48 AM
Ferguson TE20 Ford Engine Swap? EngineBob Antique Farm Tractors 6 01-01-2013 11:36:18 PM
Ferguson TO-20 Bill Thelemann Antique Farm Tractors 1 04-13-2008 05:30:52 PM
