Planet Jr/ Briggs and Stratton 8-R6
this thread has 4 replies and has been viewed 332 times
Old 07-10-2019, 09:02:56 AM
Aucuba Aucuba is offline
Default Planet Jr/ Briggs and Stratton 8-R6
Recently aquired a property that was vacant for the better part of the last decade. Buried in the barn amonst other thing I found a 1950's Planet Jr walk behind tractor, brush hog blade, tiller, and plow. Looking for a place to get parts to get it running again. Briggs and Stratton had this forum on their list for getting that sort of information.
ID:	338849   Click image for larger version
ID:	338850   Click image for larger version
Old 07-10-2019, 02:56:06 PM
Arlie Levy Arlie Levy is offline
Default Re: Planet Jr/ Briggs and Stratton 8-R6
Most of the time you don't need parts.Just take it apart clean the points real good. Clean the sump out. Be careful not to break the gasket if possible. Use formagasket when you reassemble. This is just to get it running. If you are real fussy and restore it then parts are available from vendors on this site
Old 07-10-2019, 11:41:59 PM
ulgydog56's Avatar
great find and with blade, worth the effort to bring her back....
Old 07-11-2019, 10:23:32 AM
Like I said it also had the brush hog and tiller.
ID:	338886   Click image for larger version
Old 07-11-2019, 10:25:41 AM
Good to know as far as parts. Just looking over the motor it looked to missing a filter or something on the one side, maybe an air filter.
Briggs and Stratton, Wanted 16 HP Briggs Decal cobrajetken Garden Tractors and Mowers 0 03-28-2019 08:33:12 AM
Briggs & Stratton FJ 2 #462 Everett Hayden Small Air Cooled Gasoline Engines 9 07-07-2018 09:45:04 PM
BRIGGS NPR6 on Planet Junior planter senior Garden Tractors and Mowers 2 06-12-2012 03:02:26 PM
Briggs & Stratton 3hp Jim M. Small Air Cooled Gasoline Engines 3 08-20-2010 10:36:07 PM
Planet Junior BR6 Briggs engine darrin Garden Tractors and Mowers 2 12-18-2008 09:56:30 PM
