Help identify JD grill/nose.
this thread has 8 replies and has been viewed 449 times
Old 07-11-2019, 09:31:46 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default Help identify JD grill/nose.
Hello all. I picked up some jd parts today at a garage sale. I'm trying to figure out what tractors they may be for? I believe the 1st and 2nd pic shown might be from a 720/730 model? I have no idea in pic 3 and 4 what that nose is from? Asking for some JD knowledge that can be shared here with these. Thank you
ID:	338903   Click image for larger version
ID:	338904   Click image for larger version
ID:	338905   Click image for larger version
The Following User Says Thank You to Firewoodguy For This Post:
Old 07-11-2019, 10:02:45 PM
GADavis GADavis is offline
Default Re: Help identify JD grill/nose.
# 3 & 4 are for the Dubuque built tractors.
The Following 3 Users Say Thank You to GADavis For This Post:
Old 07-11-2019, 10:18:05 PM
The first two are or look like they are from a 520 ? and the other two are 320 or 420
Old 07-11-2019, 10:42:41 PM
If I counted correctly the one at the left has 11 pleats so would be for a 620/630.
Old 07-11-2019, 11:22:06 PM
Craig, yes 11. Appriciate the identification. The other grill might be from or for a 320/420 Dubuque as GAdavis stated. I never heard that term Dubuque, but I did some google search and couldn't find that grill color scheme. Could someone possibly tell me what year tractors would be fit to? Then the next thing would be I guess is find someone who needs them. I know someone spent some time restoring them! As I'm learning here,the 520 had how many pleats?
Old 07-11-2019, 11:39:35 PM
I took better look at the one at the right...….
John Deere 820 and later......that's a BIG nose piece.
Old 07-12-2019, 09:10:39 AM
ronm ronm is offline
One on the right has to be a Dubuque tractor, I'd guess 420 if I had to guess, due to the Dzus fastener at the back, also the radiator neck hole is on the left side. Waterloo's were in the center, like the first one.
Only way to tell for sure what it fits is measure the width against a known one...
Nice find, somebody did put some work into them for sure...
Edit: Not a 420, the grille goes all the way across...I'm lookin'...
Edit again: 420-430 CRAWLER...REALLY nice find...
Smokstak member #442
The Following 2 Users Say Thank You to ronm For This Post:
Old 07-12-2019, 11:58:41 AM
Dubuque Iowa was the factory where the 2 cylinder upright engine tractors were made and Waterloo Iowa was where the laying down 2 cylinder tractors were built.
The Following User Says Thank You to GADavis For This Post:
Old 07-13-2019, 12:44:56 PM
Ron, appreciate that info.
482 Bullet Nose Betty Project CNR6069 Steam Stationary Engines, Traction Engines 5 11-28-2014 09:59:18 AM
Spindle nose Tony B. Machine Shop and Tool Talk 2 03-06-2010 05:28:01 PM
