Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
Goulds mudsucker diaphram source needed
this thread has 2 replies and has been viewed 187 times
Old 07-27-2019, 03:04:31 PM
Question Goulds mudsucker diaphram source needed
My engine club has a Goulds mudsucker that was salvaged from a zinc mine in franklin NJ. It was brought up by scuba divers from the floodd mine in the 1960s. Now, after over 100 years, the rubber diaphran is finally splitting, and needs to be replaced. does anyone have a source for these? A local Goulds dealer states he no longer deals with these pumps, only domestic water parts. We really need to replace it, as the pump is a local peice of history, and we hate to think of just putting it in a corner to look at.
I believe the diaphram is about 14" in diameter, and is about 1/2" thick
Thanks for any help.
Old 07-27-2019, 03:54:49 PM
Default Re: Goulds mudsucker diaphram source needed
I purchased a diaphragm from Graingers a few years ago that was about that size, I've seen several pumps that were similar that all used that same diaphragm, not sure if it would fit your pump.
Just looked up my old thread on that pump, seems I never took any pics of it. Grainger still sells the pumps, does it look anything like this https://www.grainger.com/product/DAY...AS01?$smthumb$
I've seen gasoline powered versions and dual diaphragm versions, some fairly old.
Old 07-27-2019, 04:37:21 PM
Walt Potoniec Walt Potoniec is offline
Andrew, Try evil bay. Search ( Herco replacement diaphragms) Size #4, is 14-1/2 OD and 5-1/2 cut out center.
Goulds mudsucker Diaphram needed Andrew Mackey Farm Antiques and Collectibles 2 11-30-2018 05:14:26 PM
Source for springs needed BobM Hit & Miss Gas Engine Discussion 5 11-05-2010 10:52:00 PM
Source for gear blank needed W.P.Klein Hit & Miss Gas Engine Discussion 3 08-24-2005 10:32:00 AM
Goulds Tri-Plex Pump Info Needed. Smoke Hit & Miss Gas Engine Discussion 1 06-04-2005 01:20:06 PM
W3M Parts source needed.. Allen Underdown Generators & Electric Motors General Discussion 0 09-21-2003 08:01:02 PM
