John Deere LUC engine governor, adding hand throttle
this thread has 2 replies and has been viewed 260 times
Old 08-03-2019, 06:06:44 PM
bmklawt bmklawt is offline
Default John Deere LUC engine governor, adding hand throttle
I'm using a LUC engine coupled to a Model A transmission and axle on a small homemade tractor I'm building, the LUC engine has as far as I can tell just had slow and fast idle controlled by the governor. When I hook up a hand throttle to this, do I hook it up to the governor or take the linkage from the carb to governor off and hook my throttle directly to the throttle shaft on the carburetor?
Your help is greatly appreciated,
Bruce
Name:	LUC carb throttle.jpg
Old 08-05-2019, 03:00:35 PM
ronm ronm is offline
Default Re: John Deere LUC engine governor, adding hand throttle
Hook your throttle lever, cable, whatever to the arm on the governor that pulls on the gov. spring. Whatever you do, don't disconnect the governor unless you want to see what it looks like with a rod hanging out the side of the block...
Smokstak member #442
Old 08-05-2019, 11:42:46 PM
ulgydog56's Avatar
ronm,s right, you can always adjust the governor, get a luc or a la john deere manual (same motor)….
1954 John Deere 60 throttle adjuster J Ware Antique Farm Tractors 2 11-06-2018 10:12:52 PM
Adding a water pump to a John Deere G Johnny D 1837 Antique Farm Tractors 3 02-24-2016 11:28:07 PM
John Deere 40C. Adjusting throttle control link from governor to cab. crawfish Farm Antiques and Collectibles 1 06-17-2013 08:38:40 PM
Adding another to the shed - 1941 John Deere A Repo Antique Farm Tractors 55 09-08-2011 11:27:58 AM
1929 John Deere D throttle setup Mike Inglis Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 14 07-26-2006 04:54:15 PM
