Case model L - freeing the engine with vinegar?
this thread has 2 replies and has been viewed 394 times
Old 08-11-2019, 09:05:26 AM
Kkliev Kkliev is offline
Default Case model L - freeing the engine with vinegar?
Hey folks. I just purchased my first antique tractor, a 1929 Case model L. The engine is seized. I donít know how bad yet because I havenít drug it home yet. I want your option on freeeing the engine using vinegar. I had really good luck using vinegar to free cockshutt 770 diesel. What are the pistons and ring made of in the case?
Old 08-11-2019, 09:27:23 AM
Molinegb Molinegb is offline
Default Re: Case model L - freeing the engine with vinegar?
Tractors of that era were all cast pistons. ATF and paint thinner. Half and half is best formula.
Old 08-11-2019, 11:06:18 AM
Turbo's Avatar
Turbo Turbo is offline
In my experience using vinegar to de-rust parts, it will very efficiently remove rust from steel but NOT cast iron. I'm not sure why? I have always used a light penetrating type of oil to try to free up stuck engines.
The Following User Says Thank You to Turbo For This Post:
Model of a CASE engine #2 Mike Rohrer Steam Stationary Engines, Traction Engines 5 06-11-2013 12:46:59 PM
Model Case Traction Engine ListerDiesel Scale Model Engineering 0 09-13-2008 03:05:35 PM
