1938 Case R
this thread has 7 replies and has been viewed 570 times
Old 08-12-2019, 05:03:25 PM
DanLyle89 DanLyle89 is offline
Default 1938 Case R
Hi I have a 1938 Case R that has an older restore. Thinking it will be the next project would anyone happen to have an original seat bracket for it and a starter filler plate for the Waukesha? It has a starter on it but I donít think it was originally equipped and it starts second pull of the crank. Thank you for any help
The Following 4 Users Say Thank You to DanLyle89 For This Post:
Old 08-12-2019, 06:24:33 PM
casertractor casertractor is online now
Default Re: 1938 Case R
It is a 1939 model with the sunburst grill one of only 500 made in 1939.Some of them had fully rounded fenders and some had the ones like your tractor has.Early ones had a Splitdorf magneto and later ones used a Case magneto later on a electric starter conversion was used for starting.The R came on steel or rubber.From what i know most of the R's ended up in Western Canada
The Following 2 Users Say Thank You to casertractor For This Post:
Old 08-12-2019, 07:27:22 PM
Sorry I meant to put 39 the serial number starts with 42. This one had a homemade starter switch and battery box both very crude. The guy I bought it from put the starter on it as he was in his 80s but didn’t have the filler anymore so it was definitely a hand start. Do you know of any seat brackets it is also a homemade unit on this one.
The Following User Says Thank You to DanLyle89 For This Post:
Old 08-12-2019, 10:09:34 PM
The seat bracket should be a piece of angle iron.With the seats on the R their were two different ones used in 39/40 one was a flat pan seat the other was the more rounded pan seat wich was also used on other tractors in the mid to late 1930's and later my guess is seats and fender styles were optional at the end of production of the model R?
Old 08-15-2019, 08:44:18 AM
Molinegb Molinegb is online now
Had same model R few years ago. Traded for a MM UTC.
The Following User Says Thank You to Molinegb For This Post:
Old 08-15-2019, 10:14:42 PM
Iíve always wanted a UTC and a JD AH to go with my MV
The Following 2 Users Say Thank You to DanLyle89 For This Post:
Old 08-16-2019, 09:23:57 AM
Know of 2 UTC both here in MB. They are big tractor. 6 ft 6 to top of rad.
Old 08-17-2019, 12:22:13 AM
Same height as the MV almost exactly lol never seen an AH in person they almost look like they’re even a bit higher
1938 Case L Paul Leatherman III Antique Farm Tractors 1 05-06-2017 12:49:39 PM
1938 Case R Rich Mueller Sr Hit & Miss Gas Engine Discussion 0 10-10-2015 10:08:07 PM
Case C 1938 Magneto What fits ? cerwin Antique Farm Tractors 5 12-15-2011 09:02:39 PM
1938 R Case KevinR Antique Farm Tractors 14 04-19-2011 07:07:21 AM
1938 unstyled R Case tractor KevinR Antique Farm Tractors 9 09-20-2007 10:18:24 PM
