Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
Caterpillar D8 Series 2U Dozer Value
this thread has 5 replies and has been viewed 357 times
Old 08-13-2019, 06:10:33 PM
dodge59 dodge59 is offline
Default Caterpillar D8 Series 2U Dozer Value
What's a running D8 2U worth?
As of right now, all I can say is runs haven't tried to move it at all main focus is running.
ID:	341401   Click image for larger version
The Following User Says Thank You to dodge59 For This Post:
Old 08-13-2019, 08:10:07 PM
Default Re: D8 2u
Well, for the folks in the know to be able to help you ,you might want to post a picture or 2,or perhaps let them know if it runs, how the undercarriage is and so forth. There is conditions from Burnt and rusted on up to like new. and the value is going to swing alot between those points.
Old 08-13-2019, 09:30:42 PM
Default Re: D8 2u
$2500 Canadian if it moves. For reference....https://www.purplewave.com/auction/161027/item/K1480
The Following User Says Thank You to David Hoover For This Post:
Old 08-13-2019, 11:29:03 PM
ulgydog56's Avatar
Default Re: Caterpillar D8 Series 2U Dozer Value
a worn undercarriage cost a hole bunch a money and time, many dozers were stopped being used for that reason, id give a little above scrap value because the engine runs...could turn into a big project...good luck...
The Following User Says Thank You to ulgydog56 For This Post:
Old 08-14-2019, 08:37:19 AM
Tracy T Tracy T is offline
yep, under carriage dictates price, you can easily sink more into the under carraige than another whole machine. I have two tracked machines that i bought as a pair, and didnt know what to look for got burned on one machine! 10 rollers @ $159 each, 2 track chains for $1500 along with rebuilding the grease jacks runs into $$$$$$$ and that was with doing the labor myself. not to mention if you need track pads and the bolts to put them back on and there is a bunch of them! usually 4 per pad X how many pads.
Old 08-14-2019, 07:17:53 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Yes, crawlers aren't for the meek. But then again they do offer the ultimate challenge! Moving a long time sitting dead one can be super challenging! For some strange reason the older I get the more of those money pits that seem to end up here, kinda like stray cats!
Caterpillar Series H D8 - 1950's casertractor Vintage Construction Equipment 0 10-30-2018 02:48:44 PM
Caterpillar No. 14 Series B Motor Grader casertractor Vintage Construction Equipment 0 07-10-2018 11:49:56 AM
D8 Caterpillar Dozer, 2U Series Caterpillarcrazy Dozers and Crawlers 23 06-23-2016 07:46:10 AM
Caterpillar D4 Dozer Value M&WJOE Dozers and Crawlers 3 06-19-2014 09:50:34 AM
D2 Caterpillar dozer Caterpillarcrazy Dozers and Crawlers 9 01-26-2010 10:45:57 AM
