Farmall F20 unknown front end
this thread has 11 replies and has been viewed 739 times
Old 08-19-2019, 09:24:04 PM
Travis's Avatar
Travis Travis is offline
Default Farmall F20 unknown front end
Hello everyone. I have had this F20 around 6 years now, but I have been having trouble finding any information on its odd angle front end. I have found out that some people called it a pigeon toe. And that a few years back I stopped at my local IH dealership and they let me look through an old manual. I remember it having the front end as a option, but I never had it copied down. Does anyone have information on it? Was it just for turning purposes? The front tires rub lightly and have a notion of wearing on the side because of the sharp angle.
---------- Post added at 09:24:04 PM ---------- Previous post was at 09:07:29 PM ----------
A few photos
The Following User Says Thank You to Travis For This Post:
Old 08-19-2019, 09:33:34 PM
Travis's Avatar
Default Re: Farmall F20 unknown front end
Here are some photos.
ID:	341818   Click image for larger version
ID:	341819   Click image for larger version
The Following 2 Users Say Thank You to Travis For This Post:
Old 08-19-2019, 11:33:27 PM
ulgydog56's Avatar
I beleave its to row up dirt (raise) as your working the field ..
The Following User Says Thank You to ulgydog56 For This Post:
Old 08-20-2019, 04:59:28 AM
Tracy T Tracy T is online now
I have seen that setup on other tractors and I believe the sharp angle is to help keep the tractor going straight when plowing, not much weight up front when pulling a plow!
The Following User Says Thank You to Tracy T For This Post:
Old 08-20-2019, 08:44:33 AM
Travis's Avatar
Would anyone happen to have the manual with a photo/information of the front end? I'd like to do a print out for shows.
Old 08-20-2019, 09:19:27 AM
sorry, no information on my part. try googling tricycle farmall, lots of pictures and maybe some information as well! I was reading in one post and the claim was easier to get around in tight spaces and easier steering "pre powersteering" and alot of youngsters would help with the crops.
Old 08-20-2019, 01:49:15 PM
Russ Hamm's Avatar
Self steering in lister ridges.
Old 08-20-2019, 03:05:16 PM
Heins Heins is offline
I have see guys make spacers about 6" wide that would move each front tire out so they would walk on top of a listed ridge.
Old 08-20-2019, 10:56:51 PM
Travis's Avatar
I'm afraid I'm not following. Lister ridges? I apologize if I might be sounding ignorant.
Old 08-21-2019, 08:40:54 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
In dry land farming, they plant the crop between high ridges created by a special plow mounted on the rear of the tractor. It also had the planter unit on the plow. Doing both operations in one pass. The plow was referred to as a Lister planter. the deep furrows preserved the moisture and cut down on wind erosion. When cultivation was needed the front wheels were set to follow the ridges, either straddle the ridge or follow the furrow, depending on what operation was needed.
Old 09-01-2019, 12:23:31 AM
ecclap ecclap is offline
Travis that front end was not specified for lister ridge farming. It was used in narrow planted row crops such as potatoes where having the extreme camber helped keep the front wheels away from the plants. Same principle as a single front wheel. Your rear wheels are also special for narrow row crops planted in roughly 34" rows. They utilize a split ring type rim welded to a blank band to which the spokes attach. Given that wheel equipment, it wouldn't surprise me one bit if that tractor was used on a potato farm.
Old 09-09-2019, 07:05:22 PM
Duey C Duey C is offline
Sorry to bump this Travis but do those narrow rear wheels turn that F-20 into a normal width tractor?
I'm glad I looked into your thread again as I finally, really notice the rear wheels.
I think I'm jealous.
1944 Farmall M front end MarkBillesbach Antique Farm Tractors 5 09-14-2016 08:21:44 AM
IHC Farmall front wheels Roy V Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 11-12-2015 10:35:46 PM
Farmall A Front Hitch Jim Sears Antique Farm Tractors 2 09-01-2015 07:20:19 PM
Farmall A1 front axle kerlin2014 Antique Farm Tractors 4 05-31-2015 10:51:11 AM
Farmall F20 Wide Front Kevin Watson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 02-19-2013 09:05:34 PM
