Winch advice
this thread has 24 replies and has been viewed 9826 times
Old 08-28-2005, 10:38:51 PM
MoRo's Avatar
MoRo MoRo is offline
Default Re: Winch advice
Glad you make mention of the dangers of a cable under strain. I have vivid memories of a railcar mover cable that broke and "spanked" me. No serious injuries, but twenty-four years later, I can still feel that jolt.
~M~
Old 08-29-2005, 03:33:36 PM
John G John G is offline
Andrew, thanks for the warning about the 7 pin RV connector. I think I will go buy a fusible link now.
John
Old 09-05-2005, 12:58:55 PM
Frank Y's Avatar
Frank Y Frank Y is offline
I just want to thank everyone who responded with this post. I went ahead and got the winch last week and ordered the steel to make the mount. Yesterday and today I got everything put together and welded to the trailer. The winch is now easily removable so I can use it with the truck if I want. Now I just gotta get a plug to power it up and run the wire on the truck.
Again, Thanks everyone for the advice!
And thank you HARRY!!!
Frank Y
Old 09-05-2005, 10:14:09 PM
John Davidson John Davidson is offline
eMail NOT Working
It was mentioned on one of the threads about the short remote cable. I have a Super Winch 4500 which I have had and used for over 5 years. Would recomend it. As for the short remote that came with the winch, I cut the 3 wire cord and put a grounded male plug on one end and a female end on the other end. Then I can put any length extension cord ( with ground) in the middle. Did that with my remote and have used it with a 50' cord in the middle moving engines around the yard or a 10' cord to load engines on the trailer.
Old 11-02-2006, 12:27:32 PM
D Pratt D Pratt is offline
I solved my winch problem with a Hyd winch & a home made Hyd pack powerd by a 5 1/2 HP honda Gas engine Is a little slow but haven't found any thing it won't load . Mounted winch on floor of trailer front . Mounted eye hook in front & one on rear of trailer to two block if need be . can use with any TV or tractor don't need bat. .
IH Winch Engine casertractor Hit & Miss Gas Engine Discussion 1 10-21-2018 10:37:58 AM
Venom Winch 12V DC Winch Control Dwayne Oxford Machine Shop and Tool Talk 4 05-14-2018 11:57:49 AM
TXE winch, Mod. 120 Dwayne Oxford Machine Shop and Tool Talk 0 10-23-2017 06:06:24 PM
Need help with winch JHFoster Antique Marine Engines and Outboard Motors 1 10-22-2009 03:53:20 PM
Need advice on a winch Chris Kirk Trucks, Trailers and Hauling for Shows 11 10-16-2004 08:16:03 PM
