Steam Engines
Scale Models 1/4, 1/3, 1/2, ect
this thread has 387 replies and has been viewed 84729 times
Old 01-28-2013, 11:07:56 AM
John Deck John Deck is offline
Default Re: Scale Models 1/4, 1/3, 1/2, ect
Jim that is possible Tom had a habit of using what he had on hand when it came to that. But the majority were built with 2". The other issue to take into account is when you figure flue placement you need to make sure you have an adequate wash out plug in the front. Alot of this depends on what engine you are trying to model and what scale. The smaller the firebox the more issues you will have with keeping a head of steam. Fireing methods also come into play and just stuffing the box full does not mean you will have plenty of steam. We have learned alot as we have restored our 1/2 scale Case about what works and what doesnt. We dont use coal as our main fuel, wood works best and once we have a good fire we will sprinkle some coal on top to give it some effect. 2" X 2" and 3" X 3" work very well cut to about 20" work very will in our firebox with smaller stuff to fill in the holes. Smaller dia. wood and more of it on a regular basis will give you more heat due to the increased surface area that is burning.
John Deck
Old 01-28-2013, 12:37:47 PM
DianneB DianneB is offline
Originally Posted by Nick S. View Post
Ok scale makers. I have a question. Do you fudge any of the dimensions on your boilers to give you more heating surface area or do you just put as much flu area as possible. Any insight would be awesome!
Pick up the book "Model Boilers & Boiler Making" - it has all the design formula.
Steam and water do NOT scale down so a boiler that steams well has to be designed in its own right.
For my 1/2 scale Russell I took the outside dimensions from the prototype and designed the internals from scratch. Doing all that also tells you what your limitation is for cylinder size/RPM to avoid running out of steam.
The Following User Says Thank You to DianneB For This Post:
  #303
Old 01-28-2013, 03:59:38 PM
Clooper Clooper is offline
Figured I'd post my engine as well! 5/8 scale Case. Not the nicest, but just as fun to me! First photo is in OH where we went and purchased, second photo is at the local fairgrounds awaiting restoration.
ID:	156322   Click image for larger version
Old 01-28-2013, 06:38:35 PM
Paul Leatherman III Paul Leatherman III is offline
Photo Re: Scale Models 1/4, 1/3, 1/2, ect
I thought i would contibute a little something here. This is Ricky Ritchies half scale Case. He and his father Glenn built this engine from scratch. It is absolutely awesome and so much fun to run. This picture was taken at the Shenandoah Valley Steam and Gas Engine show at Berryville Va in 1998 i do believe. I am the owner of the 1922 50 Horse Case pictured with it. Rick and Glenn are the best machinists i know bar none. And they are like family as well. Seated on my engine are my father Paul Jr and my brother John Mark. More about my engine another time
The Following 2 Users Say Thank You to Paul Leatherman III For This Post:
  #305
Old 01-28-2013, 06:48:08 PM
Well i like it
Old 01-28-2013, 06:55:03 PM
butch vollmar butch vollmar is offline
John! You're absolutly correct in small pieces of fuel being either wood or coal. I have two ARUs and one has 2" flues and the other has 1 1/2"
flues. Under a load the 1 1/2" flue engine bounces back to pressure quicker that the 2" engine due to the added heating surface. However bigger pieces of fuel doesn't provide the heat that the smaller ones due. I feel this is where most engineers with scale engines get into trouble as they try to feed the bigger stuff. It doesn't work on a scale engine. BV
The Following User Says Thank You to butch vollmar For This Post:
  #307
Old 01-30-2013, 11:15:18 AM
Nick S. Nick S. is offline
Everybody's input has been noted and taken. I really appreciate all of it! Now to answer some of the questions. What I would love to build is a 5/8 scale 30-98 double side mount Nichols. She'll be a beast!
Old 01-30-2013, 12:42:53 PM
I like it. I would be proud to have that engine.
Old 01-30-2013, 03:16:16 PM
Where can a guy find decent Pickering governor's and throttle valves for the half scales. Really the governor for a 5/8 scale would be about a 2" so that's probably what I would use.
Old 01-30-2013, 03:38:07 PM
LarryT LarryT is offline
The Terning half scales use a 1" governor.
Larry T
Old 01-30-2013, 04:01:31 PM
Larry T
Ternings also machined his governors.
Jeff
Old 01-31-2013, 11:51:07 AM
3/4 ADVANCE 3/4 ADVANCE is offline
Question Re: Scale Models 1/4, 1/3, 1/2, ect
Hi Nick; I have a 1 1/4" feeding my 6" X 8" cylinder. I would think a 1 1/2" would probably have enough flow for you. Perhaps someone can post a chart for suggested dia. of a governor to feed so many cubic inches of cylinder. Your two cylinders will need more than a half scale Case 65, but I think 2" would be overkill. JMHO. Hope this helps, 3/4A
The Following User Says Thank You to 3/4 ADVANCE For This Post:
  #313
Old 01-31-2013, 06:53:08 PM
Terning used a ball valve for his throtle it is a heavy duty one that has replaceable seats it is bolted together and he used it also as a union in his plumbing from the steam dome to the gov. He fabricated a new lever to match his linkage.
Will post pics when I can.
John Deck
Old 01-31-2013, 09:39:36 PM
I know when you scale pipe sizes, it doesn't come out right. So in my mind scaling the size of pipe is like scaling the size of cylinder should come close I would think. So 5/8 scale of a 3" steam line comes out to be 1 7/8". Maybe I'm all wet, I don't know. I do like your suggestion for a chart tho!!!
To give some rough dimensions of my future engine,
Boiler dimensions might have to be tweaked a little.
Cylinders: 4 9/16" x 6 5/8"
Barrel
Dia: 25"
Length: 111"
Fire Box L: 32"
W: 22"
H: 35"
Flues:
No: 24
Dia: 2"
Length: 59"
Flywheel
Dia: 25"
Face: 7.5"
Rear Wheels
Dia: 50"
Face: 25"
---------- Post added at 07:39 PM ---------- Previous post was at 07:36 PM ----------
p.s. Next time I go to Antlers Bar and Grille I might have to swing by the home of a small Advance!
Old 05-17-2014, 01:43:46 PM
There are some new models out there, any pictures of them?
Thank you!
Jeff
Old 05-17-2014, 02:48:35 PM
T James Ives T James Ives is offline
This was not built by me but I have become its 3rd owner in 9 years.
It has lost it's 'new' look and has a nice patina on it. I was contemplating a repaint next winter but now it is cleaned up I don't think I will.
It is a half scale Burrell agricultural single. Rear wheels about 40". I could have bought a nice roller for not much more but the logistics of moving that would be beyond me. I now have a 3 1/2 ton van it fits in a treat.
The Following 2 Users Say Thank You to T James Ives For This Post:
  #317
Old 05-17-2014, 02:51:34 PM
Heres another pic.
The Following 4 Users Say Thank You to T James Ives For This Post:
  #318
Old 05-17-2014, 04:55:01 PM
Fireman Jim's Avatar
Fireman Jim Fireman Jim is offline
Name:	Quarter Scale 65.jpg
This is our Terning engine. Kids and dog where also scaled down back then!
The Following 6 Users Say Thank You to Fireman Jim For This Post:
  #319
Old 01-18-2017, 03:25:38 PM
Casemaker Casemaker is offline
Minn 4 inch scale brand new listed for 10,000 pounds on uk ebay
ID:	272707   Click image for larger version
ID:	272708   Click image for larger version
ID:	272709   Click image for larger version
The Following 4 Users Say Thank You to Casemaker For This Post:
  #320
Old 02-15-2017, 10:28:38 PM
Sabercat7000 Sabercat7000 is offline
My brother an I own this little engine. We call it a "3/8" scale because its not based off of any specific engine, but has several traits of the large engines. I also attached a pic of a little project that I am close to finishing. It is roughly a 1/12 model of my uncle's 1912 FRICK contractors engine. It is made completely of wood and was made mostly by hand with some help from the wood lathe. Just thought someone may enjoy seeing new.
-Josh
ID:	275120   Click image for larger version
ID:	275121   Click image for larger version
ID:	275122   Click image for larger version
The Following 3 Users Say Thank You to Sabercat7000 For This Post:
Scale Models at Nowthen, MN '17 Nick Severson Scale Model Engineering 4 08-29-2017 10:05:12 PM
Scale Models -vs- Representations Jeff Smith Scale Model Engineering 7 01-25-2015 03:33:59 PM
Scale models / where are they now? Robert M Steam Stationary Engines, Traction Engines 22 07-18-2008 10:36:03 PM
Ihc Famous & R&v Scale Models Edwin Scale Model Engineering 1 01-02-2007 11:03:47 AM
Hartland Scale Models Wayne Lowdon Steam Stationary Engines, Traction Engines 5 02-28-2005 01:49:29 AM
