need simple explanation for GROWLER
this thread has 7 replies and has been viewed 2613 times
Old 01-27-2007, 02:21:45 PM
werfymmot werfymmot is offline
Default need simple explanation for GROWLER
Hello all, can anybody give me a simple explanation of what a GROWLER does ?
I am sending an old (1930-40's)Onan double wound(?) AC/DC (gen/starter )armature to be checked and would like to know what it will tell me. I have been told by an old motor repair friend that my armature needs a growler checkout to confirm the windings are still OK, ie not shorted(?), but I dont understand how it can do that....
Am I on the right track?
thanks
Eric
Old 01-27-2007, 02:52:34 PM
Merritt Merritt is offline
Default Re: need simple explanation for GROWLER
wikipedia knows the answer to everything...
http://en.wikipedia.org/wiki/Growler_(electrical_device)
cant explain it any better than that..
Old 01-27-2007, 11:43:01 PM
thanks Merritt, I think I am getting there...
ej
Old 02-02-2007, 06:12:58 PM
David K David K is offline
The link doesn't work anymore but I would really like to read what it once said.
I have a growler. Bought it at an auction for $4. Nobody at the auction but me knew what it was. I've read about them, know they are for testing rotors, and can even recognize one when I see it. But to tell the truth.....I don't fully understand how to use it. And I don't know anybody that can show me. Can somebody explain how to use it? Thanks.
Dave
Old 02-03-2007, 12:48:48 AM
David, I had to search in the listings on Wickpedia to find the explanation. Short version. put the armature on the growler, power up and move a hacksaw blade over the armature parallel to the axis, if it vibrates there is a short.
Eric
Old 02-03-2007, 04:34:50 AM
ListerDiesel's Avatar
Dave
Simplified Explanation:
Most of them use an AC field that is generated in the pole pieces to energise the armature that is resting there. The test is for a shorted turn in the armature, which shows by the pole that has the faulty winding around it giving out an AC field that vibrates a screwdriver or hacksaw blade that is resting in it. The name 'Growler' comes from the noise it makes when a bad winding is detected.
Transformer theory is what the device is based upon. Any shorted turn will act like a transformer winding and a current will flow through the winding generating an AC magnetic field.
A good winding won't be affected by the AC field so nothing happens on poles with good (open-circuit) windings.
Peter
Old 02-03-2007, 09:54:25 AM
sparkplug54 sparkplug54 is offline
I have a Growler, Its a 29 pound cocker spaniel. DAn
Old 02-03-2007, 11:00:56 PM
ZackaryMac ZackaryMac is offline
Re: Growler
The wife falls into this category on occasion...
Weidenhoff 701 Growler Help brownfrog Generators & Electric Motors General Discussion 5 03-17-2018 05:38:43 PM
Wedenhoff 701 Growler brownfrog Generators & Electric Motors General Discussion 0 01-05-2018 04:26:15 AM
Growler Dwayne Oxford Magnetos, Ignition Coils and Spark Plugs 1 04-22-2014 04:32:15 PM
Need a growler Rex Piekarczyk Generators & Electric Motors General Discussion 9 10-15-2008 09:55:45 AM
Simple question, maybe a simple answer? Jaeger Don C. Wiley Antique Engine Archives 6 04-05-2004 11:00:08 AM
