Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Milling machine
this thread has 7 replies and has been viewed 4700 times
Old 05-27-2007, 10:07:44 AM
john dodd john dodd is offline
Default Milling machine
I bought that logan lathe. Now I'm looking for a mill. I've been looking at the smithy lx dedicated mill. This mill is affordable and has a lot of nice features. But I don't know how long a lot of these model engines are the only specs. given are bore, stroke and flywheel dia. the easiest way to bore the cylinder that I know is to stand it up in a mill. With the engine on end plus a boring head and bar this adds up quick and needs to fit under the head. Most of the other parts are small and manageable. Has anyone run a smithy mill or even sheen one in person? Also how long is the main frame of these models with 10inch flywheels? Any thoughts appreciated and as always thanks!
Old 05-27-2007, 10:34:27 AM
Nick's Avatar
Nick Nick is offline
Default Re: milling machine
I can't comment on the mill but a right angle head would let you do the bore horizontal instead of vert. Or preferably make a jig for your lathe carriage and do them on there.
Old 05-27-2007, 10:56:29 AM
Buddy Harley Buddy Harley is offline
Most 8-9-10in. flywheeled engines run about a foot long in the body. For vertical boring a standard sized mill will be required. However, that operation can be done in your fancy new lathe. It's just a matter of set-up time. Your next tallist operation would be drilling flywheel hubs for set screws, you will need about 5in. + drill chuck to do that. So you will need about 10 in. under the spindle. You can do most operations with the lathe, it's just a matter of set-up time. In my opinion, with the influx of CNC equiptment, standard sized mills can be had for about what you paid for the lathe. Ninty percent of the mill work can be done with a benchtop type mill and what can't be done on one can be done in the lathe, again, it's just a matter of set-up time and fixturing.
If you can find a standard mill in decent shape with a DRO for around two grand, take it. The mass of the machine effects the final product, both in finish and cut time. It's hard to beat a Bridgport type mill when it comes to avaliable tooling.
P.S. You're getting there, another 5-10K and you could have a fairly well equipted machine shop!
Old 06-12-2007, 10:59:25 AM
John Davis's Avatar
John Davis John Davis is offline
Hi John,
Be glad you didn't buy a smithy because you would be spending most of your time breaking it down and then setting it back up every time you need to use the lathe or the mill. A lot of these individual castings or parts require a some mill work and some lathe work to complete the part. So this means a lot of setup time changing back in forth between the lathe and the mill. In my opinion you made the correct choice with the mill and lathe you purchased. Did you get a quick tool change post and holders for your lathe? It saves you a lot of time and makes machining more enjoyable well worth the money. Here are a few places where you can purchase a lot of different machinist tools, raw stock, machines, etc.. just about anything you would want for machining at a fair price. Also check out the suppliers here on Harry's site I believe some of them sell machine tools,etc.. Have Fun!
P.S....hope to see ya in January a the Florida show.
www.use-enco.com
www.mscdirect.com
http://www.enginads.com/bizcards.shtml
Old 06-12-2007, 03:33:12 PM
John
That's www.use-enco.com
Jim
Old 07-06-2007, 12:29:01 PM
John Davis's Avatar
John,
Here's one for your lathe..
http://www.lathe.com/
Old 07-06-2007, 05:35:17 PM
chrsbrbnk chrsbrbnk is offline
the advantage of the bridgeport style mill is that if you hang the work off the side of the table you can rotate the head over the top of it for operations too tall to fit on the table. the other limitation is the quill stroke on most bridgeport style machines is 5 inches but you can get a few more by cranking the table//knee up and down this actually might be more square anyway. I've got one of those 2/3 scale bridgeport enco wannabes its actually alot nicer than my bridgeport at work
Old 08-21-2007, 08:28:21 PM
Kenn K Kenn K is offline
John...............just acquired a Smithy 3in1 via ebay..........used, and in great shape !!!! They're great folks to call and ask questions of. Good luck !!!
Now I hope to choose the right model kit to start with !!!
Kenn
milling machine Jerry B Machine Shop and Tool Talk 4 12-29-2015 10:01:30 PM
Milling machine Jerry B Machine Shop and Tool Talk 14 11-30-2015 01:54:02 PM
milling machine john dodd Scale Model Engineering 9 06-11-2007 08:05:20 PM
Milling Machine Question holmesjsh Antique Engine Archives 9 12-13-2004 10:06:47 PM
Off Topic--Milling Machine Help Jim Tremble Antique Engine Archives 3 10-07-2003 07:53:46 PM
