MAYTAG
this thread has 5 replies and has been viewed 1588 times
Old 01-21-2002, 04:54:45 PM
Lynn Taylor
Default MAYTAG
I have a twin cylinder maytag seriel # 150576x, modle # FW-24. I am having trouble keeping it running, it will run for about ten minutes and then die. Can anyone tell me what could be the problem? Thanks
Old 01-21-2002, 07:16:48 PM
Bill Sherlock
Default Re: MAYTAG
Did you check the vent for your gas tank? Might be plugged or partially plugged. Engine will run until a vacuum is created in the tank preventing fuel from reaching the carburetor.
That's a 2 cycle engine isn't it? I assume you're mixing oil with the gas. If not, that would do it.
Old 01-21-2002, 08:28:29 PM
Bob Kern
Default Re: MAYTAG
Often times with a twin folks will run them too lean in an effort to cut down on the smoking or will run too little oil to try to accomplish the same thing. This can lead to over heating and the engine will slow and stop. Frequently if this is happening there will be a high pitched squeal as it slows down and the inner workings are stressed. You might want to make sure you have plenty of oil in the mix and that you don't have the air cap opened up too far and running too lean. Good luck Bob Kern
Old 01-21-2002, 09:13:22 PM
Marvin McCullough
Default Re: MAYTAG
You can also have a faulty coil that is opening up when the engine gets hot.
Old 01-21-2002, 09:25:44 PM
steve illig
Default Re: MAYTAG
LYNN sometimes on a 2 cylinder maytags. if the main bearings are worn, the crankcase will draw air around them, and lean out the fuel mixter. also not enough pressure is created in the crankcase, to force the mixter in through the ports hope this is some help to you good luck steve
Old 01-21-2002, 09:49:48 PM
Ed Kinch
Default Re: MAYTAG
Hi Lynn,When your Maytag quits will it turn over easy and start again?Does it make a squealing sound before or while it stops?When it quits check to see if it has spark as soon as it stops.Does it struggle to stay running or does it stop abruptly?Is there any fluid leakage at the crankshaft seals.Often it is caused by dirt being picked up in the fuel and clogging the fuel pickup screen?Many times it is caused by a condenser breakdown when hot.Let us know more of the symptoms and maybe we can help.
Ed Kinch
Maytag Washer Wanted to Display With my 1910 Maytag Car Hemi Joel Antique Washing Machines 3 09-26-2018 10:45:56 AM
For Sale: Antique Maytag 1934 wringer washer with gas Maytag engine Charley K Antique Washing Machines 1 07-24-2018 07:01:02 PM
Early Maytag Wooden Tub Maytag Washer Shelby Babcock Antique Washing Machines 16 12-30-2014 11:13:53 PM
Maytag Quick Action & Maytag Quart Can jamesrmorris1 Maytag Engines and Collectibles 4 08-01-2013 09:40:59 PM
Odd barn find Maytag runs again...Maytag prototype or farmer fix? Mac Leod Hit & Miss Gas Engine Discussion 16 11-19-2008 12:45:49 AM
