Odd barn find Maytag runs again...Maytag prototype or farmer fix?
this thread has 16 replies and has been viewed 5310 times
Old 11-15-2008, 09:39:45 PM
Mac Leod Mac Leod is offline
Default Odd barn find Maytag runs again...Maytag prototype or farmer fix?
Well, it has taken a lot of cleaning to make the carby work again (and sandblasting to clean things up...), and make the engine run. But it runs really well, and starts easy.
any thoughts?
ID:	43384   Click image for larger version
Old 11-15-2008, 09:44:13 PM
terry tabb
Default Re: Odd barn find maytag runs again...Maytag prototype or farmer fix???
i like it nice carb to, i bet it does run good,
Old 11-15-2008, 09:47:20 PM
vern0n's Avatar
vern0n vern0n is offline
I'm no Maytag expert, but I'd say that is someones own configuration. Looks like a good job. I do wonder how they did the check valve, (not the fuel check valve, but the intake check valve).
Old 11-15-2008, 09:48:40 PM
Hit and Miss kid's Avatar
Hit and Miss kid Hit and Miss kid is offline
Lightbulb Re: Odd barn find maytag runs again...Maytag prototype or farmer fix???
WOW,I would like to have that one Looks like a farmer do that one and done a super job on it as well
Old 11-15-2008, 11:02:02 PM
IronCity2006's Avatar
IronCity2006 IronCity2006 is offline
Location: Hoopeston, Illinois (90 miles south of Chicago)
The carb is a motor scooter carb I belive, very nice and not common. This is not a farmer rigged carb set up, actually factory to the scooters. I think
Old 11-15-2008, 11:31:18 PM
bstrucker's Avatar
bstrucker bstrucker is offline
It looks like one of those rare Briggs/Maytag collaborations.Whoever did it did a nice job.
Old 11-15-2008, 11:38:46 PM
Tom Martin Tom Martin is offline
Email Not Working
That mixer looks just like the one on a B&S model WMI that I used to have that came off a mower. I think it is a well done aftermarket modification. It took a machinist to do the mods, not a farmer or blacksmith.
Old 11-16-2008, 01:32:48 AM
terry tabb
yea i'd like to have it too, neet
Old 11-16-2008, 09:50:55 AM
grega's Avatar
grega grega is offline
the carb is off either a briggs NS, IS or WI
-Greg
Old 11-16-2008, 03:22:03 PM
Default Re: Odd barn find maytag runs again...Maytag prototype or farmer fix? THE ANSWER...
Ok...here it is, I bought the Maytag with out a carb a while back, and adapted a Briggs vac-u-jet to it using aluminum plate (You can find the pictures in this thread... http://www.smokstak.com/forum/showthread.php?t=35213 )
The engine ran very well, but it was not a particularly attractive piece.
I made a pattern out of wood and I cast the new carburetor mount that you now see on the engine in aluminum. I have had the mount waiting for about half of a year now, waiting for the right carburetor. Well, at the woodland swap I found it... The carb came off a WI Briggs engine. This was not a machine shop project, it was made using a few files and an old hand crank drill at home.
The check valve is a piece of coke can as a reed
it could have very well been a farmers fix, or a machinists project...and, if Briggs and Maytag had ever worked together, it may really have been The very rare "Maybriggs Engine"
I hope you all enjoy my little project- I know I did
The Following User Says Thank You to Mac Leod For This Post:
Old 11-16-2008, 06:25:57 PM
bstrucker's Avatar
What did you use for a pickup tube?It looks like a real nice job.
Old 11-16-2008, 09:48:44 PM
Default Re: Odd barn find Maytag runs again...Maytag prototype or farmer fix?
The pickup is an old brass pickup of a BS 5 hp engine (13000 series) cut down about an inch and a half.
Does any one have a pic of the scooter carb? I would like to see it
Old 11-16-2008, 11:06:32 PM
OldironJeff's Avatar
OldironJeff OldironJeff is offline
I like Frankenstein projects.
Old 11-16-2008, 11:17:28 PM
Christian Berlin's Avatar
Christian Berlin Christian Berlin is offline
how did you start it.....did you just pull the flywheel over compression or what
Old 11-17-2008, 10:36:04 AM
Starting, right... it is a little odd, I have a kicker for the engine but it is busted up real good (I think the engine was dropped once and the kicker, lever and cover took all the damage) Tried welding it (Had very good luck with mig on iron before) Spider cracks all through it. well, it was busted when I got it so nothing lost.
I stand on the skid, and put a foot on the flywheel and spin it over a couple times until it fires. Sooner or later, I will find the right starter
Old 11-17-2008, 04:13:24 PM
i did that to one of my engines also i know of some one here who is selling one for $100 it is a maytag 92 long base it is compleet
Old 11-19-2008, 12:45:49 AM
Turbo's Avatar
Turbo Turbo is offline
Very good job, I like people with a little mechanical creativity. You should be very proud, you did what it took to make your engine run without original parts. This is what many people had to do back in the depression era. AWSOME!!!!!
Maytag gen-set find. James Wallace Maytag Engines and Collectibles 2 10-25-2008 08:37:58 AM
Ugly Maytag Runs! Samuel.G Maytag Engines and Collectibles 4 10-27-2007 09:07:59 PM
First Maytag runs! Doug S. Maytag Engines and Collectibles 1 09-12-2006 07:42:16 PM
maytag find George Eddy Antique Engine Archives 0 10-19-2002 10:12:35 PM
the Maytag runs!! Corey Wey Antique Engine Archives 1 01-05-2002 04:21:47 PM
